Hello Blur Busters.
I am still using Benq XL2411p for gaming, thanks to this wonderful community, and it had been quite nice so far, but I'm coming back here after a year or so to check if there have been any further developments in the field of blur busting for lower refresh rates that might surpass the XL2411p.
Since I can't afford an expensive video card, I'm stuck at playin at lower FPS.
I've been using it at 85 hz with Large Vertical Total but it's starting to prove sometimes above what my video card can do
Also even at 85 hz, the crosstalk reduction isn't perfect (though still pretty good), and on top of that the colors are not the best either.
So I'm hoping maybe there's some new monitor that can do good motion blur reduction at lets say 75 hz. A very long shot, I know, but worth to ask.
Thank you!
XL2411p still the best for my use case
Re: XL2411p still the best for my use case
You should consider the ViewSonic XG2431 -- which has a Blur Busters Approved 2.0 strobe backlight -- it does low-Hz strobing even better than the XL2411P does. It can strobe from 59Hz-241Hz, and it has a better Strobe Utility with the ability to adjust Overdrive Gain.MST wrote: ↑13 Jan 2022, 14:16Hello Blur Busters.
Refresh rate headroom is very good for low-Hz strobing, as 75Hz strobe looks better on a 240Hz panel than 75Hz strobe on a 144Hz panel.
www.blurbusters.com/xg2431
Thank you good sir!
Unfortunately it's not yet available in my country (Romania). But I see it was released just a few months ago so maybe in the near future!
Hopefully it's not too expensive.
Happy blur busting!
Happy blur busting!
