Yes, I heard from multiple people trying them out. I also tried it. Some used same models as me, some used different ones. It works as always, better for some time, then comes back.Thatweirdinputlag wrote: ↑26 Jan 2022, 05:55Have you tried them? Have you heard of anyone trying them?
Some tests about the most complex problem in history
- dervu
Re: Some tests about the most complex problem in history
- cybepine
In that case I think it might be harmonics (EMI).dervu wrote: ↑26 Jan 2022, 06:41Yes, I heard from multiple people trying them out. I also tried it. Some used same models as me, some used different ones. It works as always, better for some time, then comes back.Thatweirdinputlag wrote: ↑26 Jan 2022, 05:55Have you tried them? Have you heard of anyone trying them?
Try my test and please tell us what happens.
I think the root cause lies in the cleanliness of AC electricity or harmonics i.e EMI (e.g. transient overvoltage spikes). Not in the incoming sine waveform or frequency.
Avoid the harmonics causing devices like a pestilence in your house. In excess of course, they cannot be avoided. That is my advice and opinion.
If it is the harmonics problem that comes from outside of your house, you cannot fix it. It must be fixed at the source by installing e.g. special filters. Only the utility can do that.
I still believe that cause of this is electricty and not something else.
If someone happens to find some kind of filter for (AC wire) ultra low frequencies (300 Hz - 3 kHz), which is intended for consumer use. Let me know too, I am interested.
Thatweirdinputlag
cybepine wrote: ↑26 Jan 2022, 12:41In that case I think it might be harmonics (EMI).dervu wrote: ↑26 Jan 2022, 06:41Yes, I heard from multiple people trying them out. I also tried it. Some used same models as me, some used different ones. It works as always, better for some time, then comes back.Thatweirdinputlag wrote: ↑26 Jan 2022, 05:55Have you tried them? Have you heard of anyone trying them?
I think the root cause lies in the cleanliness of AC electricity or harmonics i.e EMI (e.g. transient over voltage spikes). Not in the incoming sine waveform or frequency.
A while ago there's was a guy that called out his electricity company and asked them to check his AC line, they did and apparently he did need some harmonic filters to be installed. I don't know which thread he was at, he did say he will update us but he either never did or he did and I missed it..
I still believe that this cause is electricity and not something else.
Mohammedlawej99
This might be my last update
.I'm late in replying to make sure it won't come back because it has always been like this .2 months ago I bought everything new with all the accessories since then I no longer have this terrible problem, it is very sad that there is no solution to this problem
Because even in a new place, when you buy everything new, you do not know whether this place is infected as well or not, and this will cost you a new computer because the infected one doesn't back to normal forever,I personally tested this
There are two solutions: Open Twitch and watch anyone who doesn't have this problem Ask where he lives and live next to him
The second solution is somewhat expensive, which is to install a complete solar panel with its batteries and play without this polluted electricity. It was confirmed that this problem disappeared from someone I spoke to
It's a crazy problem. Why is there really such a thing?
This problem has been reported all over the world why no one talk about it?Maybe because you're going to sound crazy when you describe it to them. As many described me lol.
we Really should draw the attention of the big YouTubers to talk about it Maybe the big companies will find a device or a way to solve it.
Eonds
PC's can't get infected. That's just not how physics work.Mohammedlawej99 wrote: ↑19 Apr 2022, 21:49This might be my last update.I'm late in replying to make sure it won't come back because it has always been like this .2 months ago I bought everything new with all the accessories since then I no longer have this terrible problem, it is very sad that there is no solution to this problem
we Really should draw the attention of the big YouTubers to talk about it Maybe the big companies will find a device or a way to solve it.![]()
Mohammedlawej99
I tell you this by many tests that I did myself and you say he can't get infected??? .Good luck moving your computer around the world. It won't be normal forever. you just don't know how much I suffered from this terrible problem. Computer, laptop, mobile. They are all infected forever. They are no longer fit to play at all. since I returned to my country, I built a new PC I no longer have it, knowing that the old devices are still infected, even in a clean place, stuttering, delays are still here.The funny thing is, every time I want to remember how tragic my life was, I just plug in my old device and play with it completely garbage I don't think it's good for anything except browsing sites lolEonds wrote: ↑19 Apr 2022, 22:08PC's can't get infected. That's just not how physics work.Mohammedlawej99 wrote: ↑19 Apr 2022, 21:49This might be my last update.I'm late in replying to make sure it won't come back because it has always been like this .2 months ago I bought everything new with all the accessories since then I no longer have this terrible problem, it is very sad that there is no solution to this problem
