nofearek9
Post by nofearek9 » 09 Feb 2022, 08:45
Hello , i am new to asus monitors ,coming from a LG monitor.
i have 2 PCs connected on my monitor one with HDMI and one with DP cable with my LG i had diferent profiles/setting for each port and when i was changing the input all the settings changed according to the port i was using,does asus have similar setup ? Or all the settings you change for 1 port are the same for all ports ?
KuroTobi
Post by KuroTobi » 19 Feb 2022, 14:02
Hey i got the monitor months ago and always had a weird problem in csgo and valorant with 400fps it looks like screen tearing but not in straight lines only some parts almost as it gets blurry even when i cap them with rtss or ingame
I get the same with g sync on and off
My settings are
280hz
Od 60
Everything esle off no elmb
Im on a i5 9600k
Gtx 1070
16gb ddr4 3200mhz
And a m2 ssd crucial p5 500gb
nofearek9
Post by nofearek9 » 20 Feb 2022, 12:38
did you tried od120 ?
KuroTobi
Post by KuroTobi » 20 Feb 2022, 17:30
Yes i tried od 120 looks the same as 60 for me it appears the most when i let the fps uncapped tried to find the best cap now at 250 with 280hz when i cap it at like 270-280 its almost unplayable heavy tearing and stuttering
Uncapped is buttersmooth but rhe tearing is annoying
GOR1L4
Post by GOR1L4 » 01 Mar 2022, 21:51
I use 280hz od 80 or 120 and I feel horrible screen tearing when FPS remains at 100/140 in PUBG slow mouse, what could it be?
nofearek9
Post by nofearek9 » 04 Mar 2022, 03:16
i have pubg with no problem at all 280hz and 120od ,disable vsync both in game and on monitor ,disable smouth frame rate in game and gsync in monitor ,also make sure you are in full screen and not window,if you have nvidia GPU also try : https://exputer.com/guides/best-pubg-pc-settings/
GOR1L4
Post by GOR1L4 » 11 Mar 2022, 17:46
nofearek9 wrote: ↑
04 Mar 2022, 03:16
you don't feel tearing with fps oscillation?
Discorz
VIP Member
Post by Discorz » 15 Mar 2022, 15:58
We have a fix for VG25/279QM 60Hz input lag! From my testing latency was reduced by ∼32 ms.
roro13200
Post by roro13200 » 26 Mar 2022, 11:35
I relaunch this post.
so in all this what is the best overdrive at 240hz?
