After formatting "G-SYNC Compatible Indicator" not showing
warface9991
I don't know what happened but after formatting Windows and installing routine things like drivers etc. I guess my FreeSync doesn't work anymore. I don't see fluctuations in monitor's(LG 24GL600-F) OSD which was trying to adjust the Hz and FPS before formatting. I tried reinstalling NVDIA driver via DDU but it didn't help. I use certified DP 1.2. Thanks for your help in advance.
- jorimt
Re: After formatting "G-SYNC Compatible Indicator" not showing
Did you try an older driver or the 511.72 hotfix? I ask, because some G-SYNC Compatible users on the Guru3D forums were reporting similar issues with the 511.65 driver.
Displays: ASUS P27UCWM, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
warface9991
- jorimt
Good to hear. If you want the newest driver, they recently released a hotfix to correct this issue here as well:warface9991 wrote: ↑11 Feb 2022, 09:32Oh it seems that is the problem. I installed a very old driver and it worked. Thanks
https://nvidia.custhelp.com/app/answers ... /a_id/5320
warface9991
Thank you.jorimt wrote: ↑11 Feb 2022, 12:06Good to hear. If you want the newest driver, they recently released a hotfix to correct this issue here as well:warface9991 wrote: ↑11 Feb 2022, 09:32Oh it seems that is the problem. I installed a very old driver and it worked. Thanks
- jorimt
You're welcome.
