IPS high framerate for fps
Merk91
Post by Merk91 » 05 Mar 2022, 14:12
Hi,
I usually play warzone and call of duty multiplayer.
I have an lg 2k 180hz and my main is a zowie XL2546K
I hatr the colour and the poor sharpness of this monitor, so i want to go back to an IPS monitor.
My pc have rtx 3090 and ryzen 9 5950x.
Budget is not a problem.
Im watching berween these monitor:
-Alienware AW2521H
-Alienware AW2521HF
-AOC 24G2ZU
-AOC AG254FG 360Hz (Why no one talk about this monitor???)
Which one i will buy? I live in Italy so the new viewsonic 240Hz is not available.
Low input lag, low ghosting, good brightness, nice colour and sharpness are essential
Merk91
Re: IPS high framerate for fps
Post by Merk91 » 06 Mar 2022, 11:12
So, no one can help me?
Discorz
VIP Member
Post by Discorz » 06 Mar 2022, 11:51
What do you mean by poor sharpness? Resolution/ppi sharpness? If yes than consider 27" 1440p. You already have a good cpu and gpu to push that framerate.
Merk91
Post by Merk91 » 06 Mar 2022, 12:31
Discorz wrote:
06 Mar 2022, 11:51
I already have LG27GP850 2k 27" 180hz, but 37" is too big for me, i usually have the monitor very close to my eyes.
I see sharpness of image.. i don t know why but i don like this tn panel.. i test it for about 4 month.
What do you think about the aoc that i report? And why there is no post for the 360hz aoc?? Is it so bad?
I already see that one seller ship to italy the viewsonic 240hz.. but in total it cost me about 650$ too much for that monitor in my opinion
Discorz
VIP Member
Post by Discorz » 06 Mar 2022, 15:52
So is pixels size of 1080p 25" screen ok for you?
I assume there is no reviews on AOC 360 because all those G-SYNC models are very similar.
Get the Acer XV252QF 390 Hz if it's cheaper than Alienware 360.
Merk91
Post by Merk91 » 06 Mar 2022, 16:00
Discorz wrote:
06 Mar 2022, 15:52
I already own the 390hz, but i sent it back because it have very low brightness. I found the 360hz aoc at 550€ in italy.. is a good price tag right? Does it have good response time or is better the aoc 24g2zu? I read that it have one of the best response time
Discorz
VIP Member
Post by Discorz » 06 Mar 2022, 16:06
Merk91 wrote:
06 Mar 2022, 16:00
That monitor can get 440 nits of brightness which is alot? Even with VRB the brightness is decent. Your must of been bugged than.
Which monitors did you own before?
Merk91
Post by Merk91 » 06 Mar 2022, 17:07
Discorz wrote:
06 Mar 2022, 16:06
Merk91 wrote:
06 Mar 2022, 16:00
When i use one option the brithness was ridiculus.
Before that monitor i have alienware aw2518hf and the lg 2k i reported before
lucapieroo
Post by lucapieroo » 13 Mar 2022, 08:29
I have AOC 24G2ZU and it's very very good!!!
