Z690 usb/timer issue
pox02
Re: Z690 usb/timer issue
Post by pox02 » 21 Mar 2022, 16:20
https://www.ti.com/tool/USB-REDRIVER-EVM
Post by Slender » 22 Mar 2022, 11:59
ok, I can say that these parameters can affect something.
Legacy IO Low Latency | VarStore: PchSetup, VarOffset: 0x771, Size: 0x1
Disabled: 0x0 (default)
Enabled: 0x1
USB 2.0 Controller Mode | VarStore: UsbSupport, VarOffset: 0x2E, Size: 0x1
HiSpeed: 0x1 (default)
FullSpeed: 0x0
System Time and Alarm Source | VarStore: Setup, VarOffset: 0x873, Size: 0x1
ACPI Time and Alarm Device: 0x0 (default)
Legacy RTC: 0x1
FIVR Spread Spectrum | VarStore: CpuSetup, VarOffset: 0x2F7, Size: 0x1
Disabled: 0x0
Enabled: 0x1 (default)
FCLK Frequency for Early Power On | VarStore: CpuSetup, VarOffset: 0x127, Size: 0x1
Normal (800Mhz): 0x0
1GHz: 0x1
400MHz: 0x2
Auto: 0x3 (default)
Post by Slender » 22 Mar 2022, 12:04
as you can see, on my external controller, my mouse works on usb 1.1 and the port it is connected to also works on 1.1
But when I insert the mouse into the usb 2.0 port on the motherboard (after disabling high speed in the bios), nothing changes, the port still works in highspeed mode (at least that's what the program says, I don't know how to check in fact)
Eonds
Post by Eonds » 22 Mar 2022, 13:51
Slender wrote: ↑
22 Mar 2022, 12:04
High speed allows to the usb controller to operate faster. It's related to bandwidth.
Post by Slender » 22 Mar 2022, 14:36
Eonds wrote: ↑
22 Mar 2022, 13:51
Slender wrote: ↑
22 Mar 2022, 12:04
yes, but this causes some inconsistency, because the mouse is running at full speed, in other words, our mice do not need high bandwidth
Post by Slender » 22 Mar 2022, 17:42
as if it repeats itself
kriegor
Post by kriegor » 22 Mar 2022, 18:29
My graph looks clean with <1ms variance when I just booted windows.
It looks the same as yours with +40/-40 when I have apps running, without any affinities. It may simply be the architecture.
Z390 graphs also looks way worse when you have all the standard apps running.
But can you describe to me what exactly that polling graph is supposed to be indicative off?
Your mouse inputs are processed differently when you are on a desktop composition versus inside a fullscreen render (game).
Slender wrote: ↑
22 Mar 2022, 11:59
And I can say with certainty that you can not possibly make it more obvious you have no idea what you are doing or talking about.
Post by Slender » 25 Mar 2022, 17:58
kriegor wrote: ↑
22 Mar 2022, 18:29
Slender wrote: ↑
22 Mar 2022, 11:59
for heavy games delta 980-1020, for like cs 990-1010.
This is the only program that tells me what is wrong in the system.
And yes, I really can't say anything about these hidden settings in the bios.
Eonds
Post by Eonds » 25 Mar 2022, 20:10
Slender wrote: ↑
22 Mar 2022, 17:42
What mouse are you using in those tests?
Post by Slender » 26 Mar 2022, 15:54
Eonds wrote: ↑
25 Mar 2022, 20:10
Slender wrote: ↑
22 Mar 2022, 17:42
xm1r, pulsar xlite, viper 8khz (1000hz)
I have 12700kf and 3070ti now, test it next day
