axaro1
Post
by axaro1 » 22 Mar 2022, 04:28
wNchstR wrote: ↑22 Mar 2022, 04:01
'm undecided between Benq XL2540k, Msi MAG251RX, XG2431 and LG 27GP83b. I'll be playing 120hz Halo mostly.(Series X)
The XG2431 has a
variable-scanrate panel so you will have
no latency penalty at 60hz and 120hz,
it also does support PureXP (strobing) natively even as low as 60hz so I guess that the XG is a no brainer for consoles.
It also performs better than the MAG251RX in terms of motion clarity due to its newer 240hz IPS panel.
wNchstR
Post
by wNchstR » 23 Mar 2022, 03:55
axaro1 wrote: ↑22 Mar 2022, 04:28
The XG2431 has a
Thanks for the answer, now I'm using the Viewsonic XG240R, will there be a noticeable difference with the XG2431?
axaro1
Post
by axaro1 » 23 Mar 2022, 07:36
wNchstR wrote: ↑23 Mar 2022, 03:55
It depends, if you are not satisfied with your current monitor and you are considering an upgrade then the XG2431 is exactly what you are looking for in your PS5 setup and it comes at a reasonable price.
The XG seems like an improvement in every way: latency, clarity, colors, viewing angles...
That being said I used to play with an XG2402 (basically the same as your XG240R) myself and I acknowledge that it is a great monitor.
AquariusLuLu
Post
by AquariusLuLu » 16 Apr 2022, 15:03
What are some settings for xg2431 for ps5 gaming. I play battle royals typically apex legends. Currently, I have PureXp on low, I do find on PureXP Off mine it seems a little faster but there’s ghosting. Thanks in advance!
