Zace
Post by Zace » 06 Apr 2022, 10:39
Discorz wrote: ↑
06 Apr 2022, 03:47
Zace wrote: ↑
06 Apr 2022, 02:45
I am the founder of that problem. It’s caused by turning on custom color settings.
Do you mean when "Color Temperature > User Color" is used? Does it get more aggressive with or without it?
Yup, any other color temp does not cause overshoot, only user color cause overshoot.
wired41
Post by wired41 » 10 Apr 2022, 10:30
I had this monitor for about three days and for those three days it was awesome. Unfortunately a black horizontal line appeared on the monitor and I did everything to fix it. I was not able to and ended up returning it. The colors were amazing, I was so blown away.
peixotao
Post by peixotao » 15 Apr 2022, 18:52
Just look at the final cost if I try to import this XG2431 from the US to EU>
Order Summary
Items: EUR 292.56
Shipping & handling: EUR 39.99
Total before tax: EUR 332.55
Estimated tax to be collected: EUR 0.00
Import Fees Deposit: EUR 98.09
Payment Total: EUR 430,63
Thats nuts!!
Zace
Post by Zace » 16 Apr 2022, 13:59
peixotao wrote: ↑
15 Apr 2022, 18:52
Order Summary
Items: EUR 292.56
Thats nuts!!
Wrong! It’s calculated in USD so total would be 430 usd for you!
AquariusLuLu
Post by AquariusLuLu » 17 Apr 2022, 16:26
Really hoping I can have some settings for my XG2431 in regards to playing apex legends on the ps5. The game is currently 60FPS cap and will be 120 FPS down the road does anyone have settings that are good for both these situations? Currently I am using PureXP on low. Thanks for any advice/feedback you may have!
Cheers
Boomchakadah
Post by Boomchakadah » 21 Apr 2022, 01:41
Does anyone know how to access the service menu on this XG2431? Mine arrived today with the factory seal on the box broken. If the monitor was used before, I wanna check for how long.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
sodafly
Post by sodafly » 21 Apr 2022, 02:13
I have had this monitor for about 1-2 months now and I am still getting eye strain/fatigue whilst using it. This is my first IPS pannel and I am wondering what I can do to fix it?
I am currently using 35% brightness on the monitor with 60 black eq and Pure xp set to off. I have set red to 95 and blue to 91 on the colour scaling's and nothing seems to help.
I am not sure what I can do to fix this considering my old monitor was a VIewsonic elite TN 144hz monitor which I used to run at brighter and at 100% digital vibrance on nvidia. This monitor I barley have it at 70% cause it hurts my eyes so much.
kyube
Post by kyube » 21 Apr 2022, 05:20
Boomchakadah wrote: ↑
21 Apr 2022, 01:41
Try turning the monitor off first. Hold the Menu button and turn the monitor on while you keep holding the menu button. Pressing the menu button again should pop up the service menu (at least this is how it's done on older Viewsonic models)
Boomchakadah
Post by Boomchakadah » 21 Apr 2022, 05:44
kyube wrote: ↑
21 Apr 2022, 05:20
21 Apr 2022, 01:41
I already tried that and it doesn't work unfortunately.
wired41
Post by wired41 » 21 Apr 2022, 12:52
sodafly wrote: ↑
21 Apr 2022, 02:13
I had similar issues even though I only had the monitor for a few days. I found that turning on PureXP helped reduced the brightness to a reasonable level and the headaches lessened.
