Forgive help in choosing a monitor 27'(for competitive games)
Good day, dear forum users!
I ask for help with choosing a monitor 27 ', IPS, FHD resolution.
A monitor is required primarily for competitive play, Apex Legends, and to a lesser extent for single player games. The monitor will be the second, now I have AOC c27g1 - which unfortunately gives quite a lot of blur in dynamic scenes in Apex Legends. It was decided to purchase a second monitor to solve this problem. In addition, two monitors will be useful for work.
Perhaps the PC configuration will be useful:
amd ryzen 5600x
radeon 6600xt
32gb ram
After reading the forum outlined two potential contenders:
Asus vg279qm
and
Viewsonic xg270
How big of a difference will there be in Apex? xg270 is cheaper in my region, asus is more expensive. I will also listen to your suggestions and arguments with pleasure.
Thank you!
amd ryzen 5600x
radeon 6600xt
32gb ram
Asus vg279qm
and
Viewsonic xg270
Thank you!
Re: Forgive help in choosing a monitor 27'(for competitive games)
I would also add that in my region Asus costs $150 more.
Boomchakadah
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
I'm sorry, my fault I did not specify that you need exactly FHD resolution.
Does anyone here own MAG274QRX? I'd love to see some pursuits of it.
I've looked at reviews and monitor response time charts on Rtings.com unfortunately good response time models are either too expensive for me or don't hit the right resolution. The Viewsonic xg270 is reasonably priced and was generally well rated in the review, but would like to hear about issues with this monitor. I heard that it gives the best result at 119Hz frequency and stroboscope. How does it behave at 144Hz without a strobe? If anyone has this experience please tell me. Also, I'm still open to suggestions, preferably with arguments why this particular monitor is worth buying.
Really, there are no Viewsonic xg270 owners on the forum? TT
i recently tried the Acer XV272UX 27" 1440p 270hz. it seems to be a steal at 450€ (in germany atleast).
imo it has really good overdrive performance: https://www.youtube.com/shorts/U-0Sz1vgeKg
sadly its not for me as 27" is too big and i really can feel the processing lag of 1440p compared to 1080p.
ASUS VG259QM
SAMSUNG G60SD
I continue to deal with the choice of monitor. There was an idea to take 24 'I'm not sure if it will be good in conjunction with the 27 ' already existing monitor. What do you think of the Acer Nitro XV252QFbmiiprx? Perhaps this is the best solution for my needs? How does it compare to the Viewsonic xg270?
Thank you for your comment! Interesting monitor, but unfortunately not 1080, and the price is too high for meprod1G wrote: ↑25 May 2022, 10:21i recently tried the Acer XV272UX 27" 1440p 270hz. it seems to be a steal at 450€ (in germany atleast).
