Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
3xil3
Post
by 3xil3 » 28 May 2022, 15:48
edit
Move all cable away from back of the motherboard especially CPU power cable.
Also this post only post ive read and last all. My Prev post made no sense but thinking it was something fix within windows but its all due to power consumption and having power being MB is what causing problem I. All i did was to move everything away from back of MB dont. Do not rout cpu power cable down side move move it AWAY!! .. And it resolved issue 100% Also yes its mess IDK ive done so much trying find problem and found it i dont dare touch anything. Also n one seeing rear.
EIT
OK it seem to be thermal paste using
3xil3 on 09 Jun 2022, 08:06, edited 12 times in total.
dervu
Post
by dervu » 28 May 2022, 15:56
Great to have such detailed topic! /s
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / ASUS ROG SWIFT PG279QM / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor
Anonymous768119
Post
by Anonymous768119 » 28 May 2022, 17:53
Great! I wouldn't think it could be so easy.
See you tommorow.
Mr1991
Post
by Mr1991 » 28 May 2022, 20:09
Did I ever tell you, the definition of insanity?
Unreazz
Post
by Unreazz » 28 May 2022, 21:56
This guy finds every day a new fix, which made his mouse lag gone. At a certain point you got the most out of it and cant make it more and more responsive!
By the ammount of fixes which he discoved, his PC is allready better than NASA's
mybad
Post
by mybad » 29 May 2022, 00:01
3xil3 wrote: ↑28 May 2022, 15:48
I rewired my computer and separated all power cables away from data cables and fine now.
What do you recommend for people who use optic fibre, like a data cable? I hope you know, that type of cable absolutely doesn't care about magnetic interference.
3xil3
Post
by 3xil3 » 30 May 2022, 12:33
Sorry edited OP move cables away from back of MB
Thatweirdinputlag
Post
by Thatweirdinputlag » 30 May 2022, 15:49
So you leave the backside of your case open now? with all wires dangling? Lets hope you don't have a cat.
Rog Strix Z790i - Intel 13700K - 4090 OC ROG Strix - 7200 Trident G.Skill - 1TB SK Hynix Platinum P41 - 1000W ATX3.0 Asus Tuf - 34'' Odyssey OLED G8 - FinalMouse Tenz S/Pulsar Xlite V2 Mini - Wooting 60HE - Sennheiser HD 560s - Shure SM7b - GoXLR Mini
3xil3
Post
by 3xil3 » 30 May 2022, 17:14
Problem is the AIO i looked at hardware usage when lag happens its CPU. I separated power wires that connect to block/pump so nothing touching in back of case worked great but started feel off when opened web browser once i closed browser did nothing felt fine again. So looked at hardware and again it was CPU i over looked wires when routed them to back case. If you look at pic of my build you can see my AIO wires are being ran up over VRM heatsink they actually touching once i lifted wires so no contact its perfect regardless of hardware usage.
This explained so much all started happening when went from custom loop to AIO with pump sitting right on CPU. Custom loop everything separated. So yea hope this threads helps others.
edit
@Thatweirdinputlag
No i have back cover on.
Post
by Slender » 30 May 2022, 23:38
nyxo100 wrote: ↑30 May 2022, 22:40
stop trolling bro
he is not trolling
