akylen
In the room where I play, I have this on the wall
In the attached photo, I don't know what it is, could it cause hardware-related problems?
- thumbnail_IMG_0024.jpg (246.17 KiB) Viewed 16006 times
MegaMelmek
I have also coax everywhere in my appartment… Its voltage in it but no one was able to say where it come from they say that this voltage is inducting there bacause is close to power cables….
- E35466CC-EC66-4CD1-89E9-4020991BA4A6.jpeg (3.47 MiB) Viewed 15986 times
x7007
you need to connect something like this to the main connector or to every connector, I'm not sure at the moment, I connected this to my connector from the wall in my room between the modem while I had a floaty mouse, fast, but floaty that keep moving like it's sliding and doesn't stop an instant, now it's fast and instant. I saw in this thread that someone said how it's important to use quality 5-1000mhz or else you will have terrible terrible issues.
https://forums.xfinity.com/conversation ... 023053c8bf
"QUOTE" In an effort to try to obtain better connectivity / more wiggle room, check to see if there are there any excess/unneeded coax cable splitters in the line leading to the modem that can be eliminated/re-configured. Any splitters that remain should be high quality and cable rated for 5-1000 MHz, bi-directional, and no gold colored garbage from Radio Shack, Home Depot, Target, etc. Splitters should be swapped with known to be good / new ones to test."
COAXIAL as long it's connected to a power source (power gride) (electricity) or connected on the other way ( not your house ) still emitting data all the time and act as an antenna, there is a special plug you need to put on it to stop it from actually working. I can't find it at the moment.
fatehasfans
your mouse movements still look 'floaty' to me, they dont have the snap they're supposed to. Also, why would your internet line affect your computer? Shouldn't you have noticed a 'fix/difference' the moment you disconnected the internet? I don't think this has anything to do with the internet or it's connections - though I'm no expert.x7007 wrote: ↑08 Jun 2022, 20:54This freaking connector is what caused mayhem. it's the cable connected from my room to the other room to the living room. the electric device is from 2011!!
i called the ISP service and they'll come to replace all the sockets!
when I disconnect these even just one of the cables it's killing the internet downstairs in the living room which is like connecting from one cable to other cable it's fix the issues instant!! freaking COAXIAL
The laptop mouse is also fixed 100%!
More pictures
https://imgur.com/a/Gm0eRNN#WCOo1Fk
I had an older device since 2001! like this it's called a LOOP same plug and everything, I connected it, the modem in the living room works and sync!
mouse is crazy insane fast and accurate
Still need to replace all the other plugs! I have 2 or 3 more and to change all the old splitters.
He is not going to leave until he do them all
For some reason wifi on the modem I connected the 2001 device getting only 6mb through WIFI, but TV NETFLIX and other streaming service works perfect. wooot....
Anonymous768119
He is doing that on TV, what did you expect? He is known for fixing his input lag on daily basis.fatehasfans wrote: ↑17 Jun 2022, 20:01your mouse movements still look 'floaty' to me, they dont have the snap they're supposed to. Also, why would your internet line affect your computer? Shouldn't you have noticed a 'fix/difference' the moment you disconnected the internet? I don't think this has anything to do with the internet or it's connections - though I'm no expert.
- dervu
If you have open coax cable, just use coax terminator cap. In my case it didn't change anything.
sunrisesineast
Pro valorant streamer seems to be facing the same issue. His aim is still pretty insane though.
https://clips.twitch.tv/BrightDistinctD ... bbEL69f9wr
x7007
I work at a big bank in Israel and came to some discovery when dealing at least 15 computers per day, usually, they are almost per-same with hardware, DELL-HP OEM computers, PS/2 splitter for mouse and keyboard, mostly the biggest factor of parts are the same, the LAN and others do not really matter for us. so they are almost 100% identical, the only difference on some are Power Cables, the mouse is 125 Hz.
Our work is this. The workers have 2 computers, one IDB and one HO Windows 7, we suppose to leave them with one Windows 10 computer. so we only do windows 10 images and replace the one on the computer. While doing that unplugging the other computer and connecting the one we keep without the PS/2/VGA Switcher, the computer didn't want to turn on, I tried a couple of times and it didn't work. the power cable that was connected was called 16A 250VA QUEEN PUO QP-029, the one that I replaced it with was 16A 250VA Longwell LP-41.
With the QUEEN POU it had weird booting issues, it didn't want to turn on or cause booting issues. after I replaced the cable it boot up instantly and I noticed the mouse move like 1000 hz 1ms latency.
So I took the same cable and connected to my laptop instead of the other cable in the picture and I saw an improvement, I am going to replace my desktop computer as well and check.
You can clearly see the differences between the pins, some of them are more circular than others. The last time I checked I saw a difference between the Circular and the straight ones, it has more contact on the power plug, which might be the weird issue we are seeing with the straight ones...
Another story with my laptop is that everything was fine with it until I plugged it at work to some bad power strip and it burns out causing the cable to be burnt as well, so I replace it with some different cable I had there and I noticed that it never worked the same. I made a test just before a long time ago, taking my laptop on the battery to the living room and there was still a floaty mouse, what I didn't do is turn off the laptop after I unplugged it from the power adapter, which might cause issues while the computer was still on. so the issue sometimes will stay until you actually turn the device off and check again, which is related more to laptops, because you can keep it on and take it to another place.
https://imgur.com/a/uANbMDj
sunrisesineast
I moved to a new place yesterday. Tested valorant today. My monitor finally feels like 144hz now. Movement is clear, screen doesn't become a mess when spraying. Felt like I had more acceleration on before but now it seems more consistent and I can feel a constant delay from mouse to monitor whereas I did not get this feeling before. Will update you guys in a few days again to notify of any changes and to answer questions. Lmk if you want me to test anything.
sunrisesineast
My mouse tester plot seems to have changed. More concentrated around the 1000hz mark now. Too bad I don't have a before picture saved.
