New Asus XG259CM Freesync Premium Problem
SalamanderOnline
Post by SalamanderOnline » 18 Jun 2022, 17:00
Hey,
I need some help I hope maybe somebody has the same issue here. Just purchased the XG259CM and when activating FreeSync Premium in my Monitor Settings it tells me Freesync Premium is on but when I go into the Radeon Software to doublecheck if its really FreeSync Premium it tells me that it only is Freesync.
Is Asus advertising their product wrongly or am I just too stupid to understand whats happening. I doublechecked their Website and it says it even on the website that the monitor has Freesync Premium.
Would love some advise.
Thanks
not freesync premium.png (42 KiB) Viewed 8026 times
Discorz
VIP Member
Re: New Asus XG259CM Freesync Premium Problem
Post by Discorz » 19 Jun 2022, 17:10
I wouldn't worry about that. It's just naming thing. All you need is it to work properly.
Btw how is the monitor? Some feedback on motion performance or in general?
SalamanderOnline
Post by SalamanderOnline » 21 Jun 2022, 10:36
Pretty good, I would rate it a little better than my Alienware AW2521HF.
Only issue I am having is that the color is pretty terrible without HDR on. (Would have loved to use ELMB Sync but since you cant use ELMB and HDR at the same time I prefered better color over motion blur reduction.) :D
