Artu57
Post by Artu57 » 04 Jul 2022, 03:21
Is this monitor good at 144-200 hz ?
Inu
Post by Inu » 04 Jul 2022, 23:56
roro13200 wrote: ↑
02 Jul 2022, 13:58
I have exactly the same thing as you.
the screen turns off on its own and turns on again, even in the middle of a game!
I've had the same issue since i received, and i just kinda deal with it. Haven't found a solution.
Artu57
Post by Artu57 » 15 Jul 2022, 08:28
Hello. Can someone who has the VG259QM send me the result of this test please? https://www.testufo.com/mprt
I need this result : https://prnt.sc/XJWcQNFQB4lB
Crazyness
Post by Crazyness » 15 Jul 2022, 08:38
Artu57 wrote: ↑
15 Jul 2022, 08:28
i just want 2 chime in even thou i dont own 259QM..
this is actualy first time i used mprt test... 427-2,3 390hz (nonstrobed)
Artu57
Post by Artu57 » 15 Jul 2022, 10:19
I need VG259QM results. I would be grateful if someone could help with this
vg259qm owner
Post by vg259qm owner » 16 Jul 2022, 08:35
Please someone help I can't find LCD reduced timing in CRU settings and all color configurations except scenery are all grey.
Post by RealNC » 16 Jul 2022, 08:38
vg259qm owner wrote: ↑
16 Jul 2022, 08:35
viewtopic.php?f=2&t=10248
cheesurr
Post by cheesurr » 20 Jul 2022, 23:42
What would be the optimal settings for PUBG where my fps jumps around quite a bit, 100-250 depending on the game. I've never used any sync but started wondering if they're good for pubg where fps drop to 100ish. i dont care too much about the colors, just want the best settings for tracking, spraying and spotting enemies, appreciate any help ^__^
brw0lf
Post by brw0lf » 23 Jul 2022, 08:08
Edited because the problem persists after 1 week it returned tthe blackout problem.
virten
Post by virten » 27 Jul 2022, 06:16
best valorant/csgo settings with 300+ fps ?
