In a recent commit, some flashrom functions have been renamed. I have updated the patch accordingly.localstring wrote:i get this error:Code: Select all
mstarddc_spi.c: In function ‘mstarddc_spi_init’: mstarddc_spi.c:151:2: error: implicit declaration of function ‘register_spi_programmer’ [-Werror=implicit-function-declaration] register_spi_programmer(&spi_programmer_mstarddc);
Firmware upgrade using Linux tool, requires no hardware
pipomolo42
Re: Firmware upgrade using Linux tool, requires no hardware
Hi,
Make sure in console (terminal) you past right (full) URLlocalstring wrote:Hello, I'm from Germany and I would like to flash my BenQ 2411Z to V2 Firmware. But after executing the following commands:Code: Select all
wget -O- http://boeglin.org/static/benq/0001-Add ... ocol.patch | patch -p1
Wront URL is "http://boeglin.org/static/benq/0001-Add ... ocol.patch"
Right (full) URL is "http://boeglin.org/static/benq/0001-Add ... ocol.patch"
Just delete flashrom folder via "explorer" and start again from step: "svn co svn://flashrom.org/flashrom/trunk flashrom" and right URL.
localstring
YOU pipomolo42, YOU ARE A HERO!!! Thank you so much! After you updated the patch I was able to flash V2 and it worked.pipomolo42 wrote:In a recent commit, some flashrom functions have been renamed. I have updated the patch accordingly.
I'm so happy now
Ohhhhhhhhhhhhhhhhhhhh, thank you very much guys (Bishi and Pipomolo), I flashed my monitor from V1 to V2 in 30 minutes with Ubuntu.
Sincerely, love you <3
But where to save XL2411Z_V2_20131209_8B72.BIN? (on pc). Do I have to rename /copy it? I don't understand ANYTHING
Maybe someone can do it on TeamViewer for me?
And what/where is burn-in mode, single strobing?
XL2411Z V1.
Edit: I can't even install TeamViewer because of an error.
Edit#2:
sudo i2cdetect -l
i2c-0 i2c Radeon i2c bit bus 0x90 I2C adapter
i2c-1 i2c Radeon i2c bit bus 0x91 I2C adapter
i2c-2 i2c Radeon i2c bit bus 0x92 I2C adapter
i2c-3 i2c Radeon i2c bit bus 0x93 I2C adapter
i2c-4 i2c Radeon i2c bit bus 0x94 I2C adapter
i2c-5 i2c Radeon i2c bit bus 0x95 I2C adapter
i2c-6 i2c Radeon i2c bit bus 0x96 I2C adapter
i2c-7 i2c Radeon i2c bit bus 0x97 I2C adapter
i2c-8 i2c Radeon aux bus DP-auxch I2C adapter
i2c-9 i2c Radeon aux bus DP-auxch I2C adapter
Which one is vga? If sudo icdetect 0,1,2,3,4,5,6,7 I see only -- -- -- -- --.
8 with connected iiyama monitor via vga:
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- 37 -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- 49 -- -- -- -- -- --
50: 50 51 52 53 54 55 56 57 -- 59 -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
With disconnected only -- --
9 with and without connected monitor:
00: 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f
10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f
20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f
30: -- -- -- -- -- -- -- -- 38 39 3a 3b 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: 60 61 62 63 64 65 66 67 68 69 6a 6b 6c 6d 6e 6f
70: 70 71 72 73 74 75 76 77
Is it /dev/i2c-8 ??
sudo i2cdump -r 0-127 8 0x50 (with connected iiyama):
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 00 ff ff ff ff ff ff 00 26 cd 1a 56 01 01 01 01 ........&??V????
10: 13 15 01 03 68 30 1b 78 2a 94 a5 a4 5a 54 a1 27 ????h0?x*???ZT?'
20: 0e 50 54 bf ef 80 b3 00 a9 40 95 00 81 40 81 80 ?PT????.?@?.?@??
30: 95 0f 71 4f d1 c0 02 3a 80 18 71 38 2d 40 58 2c ??qO???:??q8-@X,
40: 45 00 dd 0c 11 00 00 1e 00 00 00 ff 00 31 31 31 E.???..?.....111
50: 30 38 31 31 39 30 30 35 34 39 00 00 00 fd 00 37 0811900549...?.7
60: 4c 1e 53 11 00 0a 20 20 20 20 20 20 00 00 00 fc L?S?.? ...?
70: 00 50 4c 32 32 37 33 48 44 0a 20 20 20 20 00 59 .PL2273HD? .Y
So I have to do same, but with i2c-8?
Replace 1 with 8 like this? Is 0x50 correct?
Do I have to download something (this patch) or everything do in terminal? I have done "multiverse" things from Bishi's post, page 5.
Standby mode is when the monitor is turned off or when it is turned on with orange led and disabled in system?
XL2411Z V1.
Edit#2:
sudo i2cdetect -l
Is it /dev/i2c-8 ??
Bumpkamill wrote:Standby mode is when the monitor is turned off or when it is turned on with orange led and disabled in system?
Thanks for helping me
But anyway I have done it! Flashed v3 firmware. It took more time ~7min dumping ~20min flashing but it worked! Thanks to pipomolo42 - You are a genius, and to Bishi for His useful post.
All this looks really complicated and i dont want to mess up my monitor
Is there any easy way to do this without hardware?
No. But You can study it without updating monitor. You will understand this and You will be ready to flash.
The main instruction site doesn't work anymore :\
So basically it's...
1. Get ubuntu live on CD / USB stick
2. Paste in a few commands
3. Profit ?
3. Profit ?
