Hello,
I'am sharing my configuration which may improve the feeling of heavy crosshair movement.
[1] Monitor settings
Navigate your monitor settings, find aspect ratio. Select Original (1:1)
[2] Nvidia scalling
To prevent monitor from displaying blackbars with original (1:1) scaling, use scaling on GPU.
[3] Nvidia game settings
I prefer having nvidia low latency set to ON.
[4] Bufferbloat
If there is additional network traffic while you are gaming, because of bufferbloat hit registration will be impacted negatively.
https://imgur.com/a/lV549K9
[5] UDP throttling by ISP
Incase you encounter UDP packet throttling by ISP, you can use cloudflare warp+ service to improve routing and bypass various restrictions.
wgcf can generate a free warp client configuration.
warp+ can also be free if you perform your research on the internet.
https://imgur.com/a/FkBsZhP
For some reason I can't attach more than three pictures.
Settings to try out for those with inconsistent mouse speed
- BTRY B 529th FA BN
Re: Settings to try out for those with inconsistent mouse speed
Never heard of UDP packet throttling by an ISP,, interesting.
FREESYNC ONhardhit wrote: ↑07 Aug 2022, 12:42Hello,
[2] Nvidia scalling
[4] Bufferbloat
this could be nice if it doesn't involve trial accounts and such. will research later D:warp+ can also be free if you perform your research on the internet.
Most adults need 7-8 hours of sleep each night. - US FDA
Sign up for cloudflare teams, it is free. Then generate free credentials with wgcf.
1. Connect with wgcf credentials, run command wgcf trace. Expected result warp=free
2. Find video on youtube how to extract warp teams (warp+) credentials with android studio.
3. Replace private key within free wgcf credentials with the extracted private key from warp teams using android studio.
4. Run wgcf trace. Expected result warp=plus
PM me if you need more detailed information.
Warp+ definitely helped. I recommend it to use it! Only use warp+ cost 5$ per month or if u want it for free u can try: https://github.com/navaneethkm004/warp-plus
I went with $5 purchase on the phone app because I just can't figure it out after an hour and i can't spend any more time on this. I don't know if it will make any differences to the gaming but eh. we will see
Did way more than those, nothing helped. U gotta realise pros don’t do these , they play default but if it helps u, it helps u
How do I get Warp+ (the paid version). I tried the free one last month, but didn't really do anything. IDK if I'm stupid- but I can't seem to find where to purchase/use the paid version.
Can you explain how this works, what i have to download ? Do i need to do this with normal CMD ? Since its not working for me
