50 bucks isn't expensive, i'll check that thing out. Ty!daviddave1 wrote: ↑06 Aug 2022, 08:43wait u play apex on wireless? ok thats a new one for me. The Edgerouter X is a great product for 50 bucks. Getting my Bufferbloat to A+ Rating def is one the better improvements i made last decade for my setup. ( I started with the Edgerouter X but upgraded now to a setup that also has the Cake protocol.)Stimpy7314 wrote: ↑06 Aug 2022, 08:09I got C. But i have no issues in other games and i'm not buying a better router for apex thats crazy. i'm the only one using the wifi 24/7daviddave1 wrote: ↑06 Aug 2022, 05:10also what score do u get for Bufferbloat on http://www.dslreports.com/speedtest ? If its not good ( A or A+) get the router on Battlenonsenses video and more on bufferbloat https://www.youtube.com/watch?v=o-g2P3R ... on%29sense It tells you exactly how to install it.daviddave1 wrote: ↑06 Aug 2022, 05:04
Why not put it in the list then of things u tried? Did u also tested it?: Do u see the windows mute button pop up inscreen if u mute the windows sound with the windows mute shortcut?
But i've been using my wifi adapter again from intel. The ax200 serie from asus. Atm i'm using wifi 6 + 5ghz mode + using warp+ from cloudflare and i disabled my realtek ethernet driver from control panel and autoruns, I must say and hopefully it isn't temporarily this time or placebo, apex has been running smooth lately for 2 days straight.![]()
Well i used to play with a ethernet cable. I've heard bad things about realtek that they cause high dpc and probably more problems that i'm not aware off. So I thought i'll use my intel wifi card that i bought few months ago (never used it, only once for apex, but didn't used warp+ and didnt also disabled my realtel driver) Since i did those two things its been getting better for a few days now
