Now you can edit BlurBustersStrobeUtility.ini to recognize regex Device ID "BNQ7FB?" (all video ports), in an edited copy and paste from Profile B to the next free INI file slot (next unused [Device##] at bottom). Then it will autodetect the XL2566K from now on.
1. Copy Profile B to a new [Device##] consecutively numbered after last [Device##]
2. Edit "DeviceID" to BNQ7FB? including the wildcard question mark in last digit.
3. Edit "Name" to XL2566K
4. XL2566K should be automatically detected on next launch
I should have a separately-downloadable INI file for all the XL2540-series and XL2560-series variants, since no upgrade to Strobe Utility is needed -- just an updated configuration file.
ZOWIE XL2566K Discussion Thread [24.5" 360hz TN]
Re: ZOWIE XL2566K Discussion Thread [24.5" 360hz TN]
![Image](https://blurbusters.com/wp-content/uploads/2024/01/BlurBustersCollectionBanner-750x80.png)
Could use a HOWTO for taking more reliable photos on a smartphone. Or we already have one? So we could give links to people that are about to do tests.Chief Blur Buster wrote: ↑21 Oct 2022, 06:12Also for stationary-camera smartphone photo, make sure smartphone shutter is at least 2x faster than refresh cycle. This minimizes chances of accidentally capturing two strobe into the same camera exposure.
Sometimes you have to download the ProCam or DSLRCamera app to do this, to force fast shutter speed.
BenQ XL2546K @ 240Hz (DyAC+) • ROCCAT Kone Pro Air @ 1000Hz • HyperX Alloy Origins • CORSAIR MM350 PRO Premium • HyperX Cloud Revolver • NVIDIA GeForce RTX 3070 @ 2130MHz/8000MHz • Intel Core i7-8700K @ 4.8GHz • G.SKILL RipjawsV 16GB (2x8GB) 3000MHz CL15
can`t this Utility be modded so that it works with any monitor ?
Not possible unless the monitor has hardware support for strobing as well as the VESA MCCS 2.2 DDC/CI commands (a sidechannel, that began as an I2C wire on VGA and DVI, for plug-n-play purposes, but also to allow computers to control undocumented settings that don't show up in the monitor menus.
However, almost all XL-series BenQ monitors have these DDC commands, but they are always at different addresses. Which is why there is Profile A and Profile B for the most common BenQ.
I could probably automatically detect if it's a BenQ-branded monitor (device ID always prefixed "BNQ") and test for existence of either Profile A or Profile B. That would be semi-universal, and is being considered for a future version of BenQ Strobe Utility. But it will only work on BenQ XL-series.
I could not get the utility to work on the XL2546K. Do u HIGHLY recommend using it? Is the difference Huge? On the XL2566K there is already a AMA? slider build in would that not make the utility overkill?) The XL2566K will arrive at my house today.Chief Blur Buster wrote: ↑22 Oct 2022, 17:40Not possible unless the monitor has hardware support for strobing as well as the VESA MCCS 2.2 DDC/CI commands (a sidechannel, that began as an I2C wire on VGA and DVI, for plug-n-play purposes, but also to allow computers to control undocumented settings that don't show up in the monitor menus.
![Smile :)](./images/smilies/icon_e_smile.gif)
| Now: ASUS PG248QP 540Hz. | Past : VG259QM with the Qisda panel/PG27AQN/XL2566K
For esports players who only play at max Hz + VSYNC OFF, usually not much benefit.
For emulator users and console-port game players (60-120fps caps), as well as people who want to use motion blur reduction at lower frame rates (e.g. Cyberpunk 2077 and other games), there can be bigger benefit If you also optimize the sync technology too at the same time.
More information about Strobe Utility benefits can be explained at:
www.blurbusters.com/strobe-utility (BenQ)
www.blurbusters.com/strobe-utility-viewsonic (ViewSonic).
The latter has new animations that explains the behaviors of a Strobe Utility better.
my example arrived today, what tools do I need to use to show you the ufo test, but I only have a smartphone, but it can shoot in slow motion.
kyube wrote: ↑21 Oct 2022, 14:33New shots have arrived! Source: DCBF_GGoki from r/monitors discord
360hz sample and hold performance on different OD levels:
Perhaps this crosstalk test might be better?
Crosstalk test @ 360hz
It does seem like you are correct, according to this:Chief Blur Buster wrote: ↑21 Oct 2022, 06:10It's almost guaranteed to be 100Hz min-frequency strobe, but please let me know if anyone is able to pull off lower-Hz strobe.
Perhaps there are some DDC/CI commands that are able to be used by the Blurbusters utility to adjust strobing? How would one look for these?
Why this look a bad??? My friend buy pre order 2566k,and look better than the picture
240 hz AMA premium
360 hz AMA premium
Xl 2546
This monitor better tnan 2546s/k on 240 hz mode and very great on 360 hz, we use premium AMA, dont know why in up picture man have good ufo in 10 AMA
Xl 2546
