Acer 390Hz monitor - XV252QF
SheerFinesse
Post by SheerFinesse » 04 Nov 2022, 02:19
VRR on or off? Pros and cons of both?
I have tried VRR for the first time for the past few days and am unsure if i play better or worse with it.
I play Fortnite and cap my frames at 387 on 390hz.
I can’t consistently hold 387 but my frames usually vary between 250-387.
I imagine VRR uses more of your GPU and could cost more performance but also increase some input lag - but improve my reaction time?
Thoughts? Recommendations?
SheerFinesse
Post by SheerFinesse » 04 Nov 2022, 02:55
I just did some research and it seems that no pro esports players use G-Sync (VRR). The only difference I can see is that we have a 390hz monitor so maybe it is more worth it? Especially since I can’t consistently hold 390fps in Fortnite
Discorz
VIP Member
Post by Discorz » 04 Nov 2022, 03:14
If u play without strobing and your frame rate is bellow 390 fps than just cap it few frames below that, enable VRR and forget about everything you read online. Capping fps bellow just keeps you inside VRR range. Exceeding 390 fps (uncapped) means you're outside range and VRR is no longer syncing or working, therefore judder might be noticed. In which case you don't need it.
Some might find VRR not helpful because screen tearing is less noticeable at such high refresh rates. Normally VRR is most effective at lower-end range. You can test this in any game, Smooth Frog is great for it. No need to worry about input lag as it is virtually non existent.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 06 Nov 2022, 19:28
pasutazame
Post by pasutazame » 15 Nov 2022, 03:34
pasutazame wrote: ↑
14 Oct 2022, 14:54
Ravannok wrote: ↑
11 Aug 2022, 07:36
Hi again.
My monitor arrived today and i have one problem. I turn on the oc in the monitor settings, SO 390hz would be avaliable. But in Windows i can choose max 360:/ anyone knows why? Is my old gpu a problem (rx580 8gb)? What can i do to make it work?
I have had experience using rx580 with 390hz. It probably works without problems on older versions of the driver (before April or previously). For 6600xt I had to update the driver and 390hz was gone.
Additional Information:
I was able to get 390hz on new AMD driver versions with CRU
Use it at your own risk
CRU -> Extencion blocks -> add -> Type displayID 2.0 -> add -> detailed res -> add -> refrashrate 390 -> ok, ok, ok, ok -> restart/restart64
390hz cru.jpg (169.31 KiB) Viewed 8825 times
attila
Post by attila » 18 Nov 2022, 06:47
Hello,
I apologize in advance for my poor English and if it's a bit long. I'm glad I found this forum because I see a lot of like-minded people here. That is why I would like to share my questions and thoughts with this community, to see if my post can help someone else in the future.
I would like to ask for your help regarding the optimal setting of xv25qf in Valorant. Should I turn off freesync and set od to extreme for the lowest latency? Can Vrb affect the delay (I can keep the 390+ fps stable, so it's more of a theoretical question, but I'm very interested)? Does anyone use it even at 390+ fps?
If I turn off freesync, does the monitor run in g-sync mode? To get the best latency so that I can keep 390+ fps stable, should I turn off gsync, vsync in nvidia control panel and just ingame limit the fps to the vrr range, maybe a little above it due to drops? All of this is due to the pursuit of balance between fluidity and the lowest possible latency with this monitor. The color space setting is srgb or, in your opinion, is there a better setting for valorant, if yes, please share your user settings with me, of course srgb would also be very interested in valorant specifically.
I really like the game during hdr, but unfortunately the same problem I experienced here also occurs during use, i.e. the screen starts flashing black. Has anyone found a solution to this?
First of all, I consider low latency to be important, which is why I chose this monitor.
I am currently using freesync with normal OD and no VRB at max hz. Unfortunately, my experience is that even though the monitor feels really fast, it often seems to lag while playing. A specific example is that after a peek, in a melee situation, I successfully take the first shot and continue the spray (I don't drag the mouse, I keep it fixed on the target, who doesn't change position), but in several such situations, it's as if I'm suddenly overwhelmed and the enemy's inputs take precedence granted, i.e. I die (all these are fractions of the moment, of course, and they don't kill me with a headshot). My internet is constantly stable at 19ms, I have no packet loss. Has anyone experienced something similar, and if so, know a solution? Currently gsync is enabled in nvidia, could this be causing this?
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 18 Nov 2022, 09:52
attila
Post by attila » 18 Nov 2022, 11:26
BTRY B 529th FA BN wrote: ↑
18 Nov 2022, 09:52
If you have an AMD card and a freesync monitor that you're not using Freesync it's best to also disable AMD External Events Utility in Services. A few drivers back I noticed it was causing a weird stutter; but this also disables game metrics, i think?
i use nvidia. amd users may find this useful, thanks!
a few posts earlier, Discorz, Kamecs and RealNc wrote about setting the low delay, but it is not entirely clear to me what the situation is and what to do when the fps can massively exceed the monitor's hz value. The monitor is also freesync and gsync compatible.
I saw you also use the monitor for fps games, what preferred settings do you prefer.
lizardpeter
Post by lizardpeter » 18 Nov 2022, 12:23
attila wrote: ↑
18 Nov 2022, 06:47
Yes, absolutely disable FreeSync and VRB for the lowest possible latency. I use it at 390 Hz. I'm not sure what you mean by "390+ FPS."
attila wrote: ↑
18 Nov 2022, 06:47
Disable FreeSync/GSYNC in the monitor's own menus and also in NVIDIA control panel. Disable VRB in the monitor's menu. Do not limit FPS to VRR range if you want the lowest latency (unless you are not using NVIDIA Reflex and are GPU bottlenecked, but that's a whole other story).
attila wrote: ↑
18 Nov 2022, 06:47
Disable HDR for the lowest latency.
OP1 8K V2 | Field75 HE
attila
Post by attila » 18 Nov 2022, 15:04
lizardpeter wrote: ↑
18 Nov 2022, 12:23
attila wrote: ↑
18 Nov 2022, 06:47
attila wrote: ↑
18 Nov 2022, 06:47
attila wrote: ↑
18 Nov 2022, 06:47
Thanks for your help. I'm very glad that you also responded because I saw that you are also a bit of a reaction time maniac.
By 390+ I mean that with such a high frame rate and frequency, many people do not see the point of VRB. Am I right that you are still using extrem overdrive? do you also use super sharpness?
Would you also like to know if you are using the contrast trick shown on the forum on this ips?
I'm using reflex, should I limit it in this case? In valorant, I noticed that if the fps is not limited, it indicates a network error.
thanks in advance!
