Plugging a PC into my outlet causes stuttering FOREVER.
lavar
Yep. You’ve read the title.
I’ve tested tons of PC’s. Took one to my buddies house, ran smooth, plugged it into my wall, stutters, back to his, stutters still exist.
No clue what is going on. Offline/Online, it is not a hardware issue.. i’ve tested tons of diff hardware.
Whatever is going on, is ruining games that do not compile shaders before hand. I have no idea why.
COD runs smooth, once I hit PUBG,FORTNITE, the graph is awful.
How the heck can something be ruining it as soon as it plugs in? Had a UPS+Power conditioner hooked up too.
Has anyone been able to solve this using a double conversion+ a whole new setup?
How the heck do I even explain this to an electrician. My outlets are “fine”. Most electricians aren’t trained for this sorta stuff.
DL’ing games onto ram dont help either .
Why the heck is it only games that do shader compilation stuff on the go / asset streaming.
Please do not post a reply if you have input delay etc. you guys have literally a million forums. It’s extremely hard to find people with a similar issue as myself.
lavar
Re: Plugging a PC into my outlet causes stuttering FOREVER.
lavar wrote: ↑18 Nov 2022, 22:49Yep. You’ve read the title.
How the heck can something be ruining it as soon as it plugs in? Had a regular UPS+Power conditioner hooked up too.
- dervu
I think there was post on this forum explaining that he had stutters from solar power inverter. It was gone after disconnecting it.
texre
Hey I know exactly what you’re talking about. It doesn’t stay forever but it does stay for a hour or 2. I have that same issue when I plug my pc into my house stutters like crazy. Then I plug it into my solar gen it stutters for 30 to hour depending on how long I kept my pc plugged into my houses electricity. You have to drain the bad energy out as crazy as that sounds I do believe I’m right.lavar wrote: ↑18 Nov 2022, 22:49Yep. You’ve read the title.
- F1zus
In a few weeks we will have an answer to this question. I have an idea why electricity causes input lag and how dirty electricity affects the computer's power supply.
Online UPS won't help you right away.
As soon as a balanced toroidal transformer is delivered to my friend, he will test it and then I will tell you what the problem was.
Do you think the problem is dirty electricity? This is half true. The main problem lies elsewhere, and soon I will tell you what it is.
For now, I'll reveal a little secret - dirty electricity penetrates the motherboard and video card. How does it penetrate? You will soon find out.
lavar
Ya. But if that was the issue here then a UPS running on battery would fix it.
That same guy replied on a YT post that he was able to fix it with a double conversion with his solar panels on.
But still my issue is diff, i still stutter with a UPS
lavar
texre wrote: ↑19 Nov 2022, 11:49Hey I know exactly what you’re talking about. It doesn’t stay forever but it does stay for a hour or 2. I have that same issue when I plug my pc into my house stutters like crazy. Then I plug it into my solar gen it stutters for 30 to hour depending on how long I kept my pc plugged into my houses electricity. You have to drain the bad energy out as crazy as that sounds I do believe I’m right.lavar wrote: ↑18 Nov 2022, 22:49Yep. You’ve read the title.
Wtf lol. I can believe that tho. So u stutter in every game or only some? What about desktop/yt vids?
Shade7
If this is for real- excited to find out.F1zus wrote: ↑20 Nov 2022, 14:05In a few weeks we will have an answer to this question. I have an idea why electricity causes input lag and how dirty electricity affects the computer's power supply.
Mr1991
So Solar power fixed your issue?texre wrote: ↑19 Nov 2022, 11:49Hey I know exactly what you’re talking about. It doesn’t stay forever but it does stay for a hour or 2. I have that same issue when I plug my pc into my house stutters like crazy. Then I plug it into my solar gen it stutters for 30 to hour depending on how long I kept my pc plugged into my houses electricity. You have to drain the bad energy out as crazy as that sounds I do believe I’m right.lavar wrote: ↑18 Nov 2022, 22:49Yep. You’ve read the title.
mago
try reflashing the bios wondering if it will change something
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
