Reducing Input Delay with Nvidia Inspector
TYT
Re: Reducing Input Delay with Nvidia Inspector
Post by TYT » 28 Jul 2022, 07:01
what does this tweaks do
DisableKmRender (0)
DisableKmRenderBoost (0)
EnableDirectFlip (1)
EnableIndependentFlip (1)
EnablePerformanceMode (1)
can anybody explain :D
Post by Chief Blur Buster » 28 Jul 2022, 21:37
TYT wrote:
28 Jul 2022, 07:01
I will chime in on this one, since this is so well known.
This is often recommended because power management can insert lag into your system.
Even simple things like framerate capping (which can cause GPU/CPU to idle between frames) might cause your computer to downclock too much between frames, causing it to be a laggard during processing mouse input, etc. So many problematic domino effects during power management in the 500Hz future, so power management should automatically be disabled when playing esports (OK to e-enable when you're not playing).
A Solid lad
Post by A Solid lad » 24 Nov 2022, 17:38
-Clean-installed 441.41
-Applied latest nvinspector profiles
-Disabled write combining
-PROFITED
omg it's so snappy, and I don't miss the frames I lost (can't even tell)
on win7, 9700K @5Ghz, 1080 Ti... full specs on Steam profile (check signature)
Discord | Youtube | Twitch
Mr1991
Post by Mr1991 » 28 Nov 2022, 16:14
A Solid lad wrote:
24 Nov 2022, 17:38
-PROFITED
Windows 7 the goat
When are they gonna make a gaming OS (sigh)
SirAndr3w
Post by SirAndr3w » 28 May 2023, 16:14
Hello, i loaded the melody mod on Nvidia profile inspector, everything's ok but,I would like to know which modification "forces" the state into "full screen" because after loading the profile and restarting my PC, every game seems to be "forced" into "full screen" mode (Of course, I have tried changing the game settings and experimenting with windowed or borderless fullscreen modes, but it doesn't make any difference). Whenever I move the mouse to the second monitor or press the Windows key on my keyboard, everything goes black for a couple seconds and it's disturbing. Which setting should I change to modify this function?
Update: I fixed it by adjusting the v-sync and g-sync settings in the Nvidia control panel. I'll leave the post visible in case it might be helpful to someone.
Riot
Post by Riot » 23 Aug 2023, 14:48
Funny seeing my .nip profile from 2020 that I made when I was 15 years old being posted here :D
iONFURY
Post by iONFURY » 14 Sep 2023, 15:38
Riot wrote:
23 Aug 2023, 14:48
good that youre back. can you explain some details whats behind your settings and what are the effects / goals of your profile? ty.
SpicyForNoReason
Post by SpicyForNoReason » 08 Oct 2023, 09:09
A Solid lad wrote:
24 Nov 2022, 17:38
-PROFITED
Is there a reason why you installed 441.41 and not any other driver before but closer to 451.48 (which apparently is where the reg edit thing stops working as mentioned in OP)
Unluckilly I have like one of the few motherboards that don't support ANY USB drivers on Win 7. I tried everything, even the 3.0 USB injector to the install media and nothing, not even the USB 2 ports work. Eventually after days of trying EVERYTHING I called MSI and they were like, "ya, usb no work w/ B360M sry".
ffs_ wrote:
06 Aug 2020, 01:14
IMHO the main improvement comes from picking certain driver version. I used to use 347.25 (Win 8.1) and it was the best for me, now I use 451.67 (Win 10 v2004), and I think it gives me the best results in terms of input-lag/mouse movement/smoothness.
Same as quote above. Why 451.67 for Windows 10? Doesn't that mean the reg edit thing mentioned in OP won't work? OP says that reg edit thing only works on 451.48 and earlier so why do an update right after it where the reg edit won't work?
Seperate question, is installing Windows 10 pre-Creators Update something people do? I hear that update incuded a lot of input lag?
Riot wrote:
23 Aug 2023, 14:48
Do you have an updated one?
TYT wrote:
28 Jul 2022, 07:01
DisableKmRender (0)
Where did you get this info? I didn't see that anywhere in the original post. Also, how do you do it? Same path as the other reg edit in original post and I assume all DWORD aswell?
mago
Post by mago » 16 May 2024, 06:47
if enabling and disabling gsync helps mouse input lag
i made bat file and nips to run it quickly each time that happen
make ur own Global 2024.nip if its needed
run 1.bat from the folder of nvidiaProfileInspector.exe
enable-and-disable-Gsync.zip
(1.41 KiB) Downloaded 315 times
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
Sandy
Post by Sandy » 29 Jun 2024, 15:03
MaxTendency wrote:
03 Aug 2020, 09:32
Simon95 wrote:
03 Aug 2020, 08:30
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\services\nvlddmkm]
"DisableWriteCombining"=dword:00000001
I cant find this in my registry.
Oh my god. Even after editing I realized that path is not correct :shock:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\nvlddmkm
This is the correct path. Things should look like this if done correctly. You obviously need nvidia gpu for this , as well as restart pc for it to apply.
Sorry for baiting everyone with the incorrect path, not once but twice :(
I've already reduced input lag without rebooting. It's very noticeable.
