[EMI] 1500mV When computer is running!!!
KingAzar
Re: EMI 1500mV When computer is running!!!
Post by KingAzar » 21 Jan 2023, 03:56
assombrosso wrote:
21 Jan 2023, 01:10
Issue can’t be fixed like this, don’t waste time into buying parts my bro
ONE TO KEEP IN MIND: Without my computer running, my EMI detection is low, it's not at 25mV for sure but it's between 60 and 80. My electric circuit is not bad.
Isolating stuff to find the culprit from my end (all cases a different) this helps me to understand more. So far my current PSU (HX850) and a brand new PSU out of the box (HX1500i) without connecting to PC are emitting high EMI to my home electric circuit. How do you explain that if my home electric circuit is low EMI
At this point from my sense, using a filter, or PSU, or Conditioner won't help. I mean it will protect other devices from my computer emitting EMI.
KingAzar
Post by KingAzar » 21 Jan 2023, 04:04
MegaMelmek wrote:
21 Jan 2023, 02:23
Pls man try same thing with that new PSU but connect iron to same outlet the numbers will be interesting…
Here is your :arrow: video: https://photos.app.goo.gl/VX4djNxnyFu3rogeA
While my PC is running, the EMI reader gives around 1480mV, when the iron (set to high) is plugged in, it reduces to around 1300mV which is still high.
One thing to note is that maybe other kinds of Iron are powerful enough to significantly reduce the EMI from the circuit, however from my own issue, this won't help because let's say I had an Iron that will reduce the EMI from 1480mV to 200mV. Only all devices connected to that outlet will have less impact from the EMI emitted by my computer, but my computer still generates EMI on the other way. :idea:
My goal is to fix the EMI that is generated by my computer which so far it's mostly generated by the PSU.
KingAzar
Post by KingAzar » 21 Jan 2023, 04:14
TheKelz wrote:
21 Jan 2023, 03:55
KingAzar wrote:
21 Jan 2023, 00:54
Another test while my PC is running.
When I tried the meter in the kitchen and the reading is 700mV instead of 70mV
Tried in the living room and the reading was 600mV
When in the basement tested in the living room, kitchen and both bedrooms reading was 400mV
When I turned off my computer all went back to normal.
Tried with the HX1500i and it went up again! So far something is going on with the HX850 and HX1500i
I found a video where someone is testing the HX1200 and not the HX1200i. I found one and I will order it for testing
HX1200 is the one youtuber Kryzzp who has zero input lag and desync issues is using. So yeah, I'm also curious if HX1200 will exhibit the same issue.
Do you have his video by any chance or channel that demonstrates his HX1200?
By the way, I just ordered the HX1200, and will arrive tomorrow - Stay tuned!
TheKelz
Post by TheKelz » 21 Jan 2023, 04:21
KingAzar wrote:
21 Jan 2023, 04:14
TheKelz wrote:
21 Jan 2023, 03:55
KingAzar wrote:
21 Jan 2023, 00:54
Unfortunately he doesn't do that type of videos.. but, all I know is that he has HX1200 (previously he had RM750x) and his gameplay is always perfect, it feels smooth and not a single desync/stutter (apart from specific games that have stuttering issues).
KingAzar
Post by KingAzar » 21 Jan 2023, 04:51
I see what you mean!
My issue is desync, hit reg issue and floatty mouse somtimes
MegaMelmek
Post by MegaMelmek » 21 Jan 2023, 12:57
KingAzar wrote:
21 Jan 2023, 04:04
MegaMelmek wrote:
21 Jan 2023, 02:23
We have to undestand that these PSU are for sure OK there is 0% chance that you got two PSU that emiting excesive amount of EMI just because thats not how this works…
I was lately talking with ppl wich and they are addicted to audio same like we do to the gaming…
They allready know that PC (most likely PSU) is emiting huge amount of EMI. They says that any switching power suply will do that if the input is bad most likely DC power in the AC system.
I am allready in proces to test all these things but my PC is in the waranty send back if you know what i mean.
MOBO- dead sound card - MSI Z790 A Pro DDR4 (1 month old mobo)
To undestand that nothing is wrong with your PSU is that there will be way more ppl with same issue like you or i have….
They explain me clearly that toroid filters get infected quickly if DC ocurs in AC system. These filters are in all PSU they small not realy build to stand DC current. I was testing big toroid filter there was for sure improvement but again lag come back.
You look like dude that realy dont care what will take it to solve this issue so pls take advice from me and stop testing other PSU there is nothing wrong with them…
I am realy sugest you look for ifi DC blocker you will have two week advatage on me.
something for read:
https://ifi-audio.com/products/dc-blocker/
dervu
Post by dervu » 21 Jan 2023, 15:10
MegaMelmek wrote:
21 Jan 2023, 12:57
KingAzar wrote:
21 Jan 2023, 04:04
MegaMelmek wrote:
21 Jan 2023, 02:23
something for read:
DC blocker was tested already by dozens of people. No lasting improvements.
MegaMelmek
Re: [EMI] 1500mV When computer is running!!!
Post by MegaMelmek » 21 Jan 2023, 15:16
I think i am kinda active there on forum and read a lot but miss that someone test it without sucsess… Even if i has to try it my self…
KingAzar
Post by KingAzar » 21 Jan 2023, 15:22
MegaMelmek wrote:
21 Jan 2023, 12:57
KingAzar wrote:
21 Jan 2023, 04:04
MegaMelmek wrote:
21 Jan 2023, 02:23
something for read:
Thank you for getting involved and adding your input. It's very appreciative
What I am hearing from you is that, while homes have AC current in the electrical circuit, DC current can also be present. From your perspective, the PSUs are working fine but because of the DC current infecting the component, this will make the two PSUs that I tested emit high EMI like we are seeing in my videos.
From your research, placing a DC Blocker on the PSU should stop the PSU to emit that high amount of EMI, correct? and therefore my reading on my outlet should be back to 80mV instead of 1500mV, am I right?
"I will try to get those DC Blockers, I header that there are two audio stores in my city that can potentially carry them"
I have other questions for you:
- From curiosity, how DC can be present in AC circuits in home? Is it coming from, a cellphone charge, a certain type of light bulb, particular device?
- How would you explain the below quote from pox2? 1 PSU is emitting a high amount of EMI and the other one is have pretty much nothing, do you think at some point he did install/change something?
pox02 wrote:
18 Apr 2021, 16:28
i have one fix for u yonaxsangi switch ur power supply with good unit with a really good emi filter like hx1200i or ssr-1000tr from seasonic looks the difference
good word about spread spectrum
spread spectrum is a hot topic of debate if it actually "works" it's just spreading out the energy some more. it doesn't reduce the overall power leakage
it helps meet the legal requirements, but the effect on actual interference is debated
sorry yonaxsangi the whole problem come from PSU
ax1600i Huge emi
https://streamable.com/hijvkt
hx1200i Extreme low emi
https://streamable.com/skoc1u
How about the below video? Is the result due to his electricity having no DC flowing into his circuit and have pure AC?
https://www.youtube.com/shorts/Qregvk8WnSI
KingAzar
Post by KingAzar » 21 Jan 2023, 15:34
dervu wrote:
21 Jan 2023, 15:10
MegaMelmek wrote:
21 Jan 2023, 12:57
KingAzar wrote:
21 Jan 2023, 04:04
MegaMelmek wrote:
21 Jan 2023, 02:23
something for read:
Dervu, do you know which DC blockers they did use by any chance?
