Viper 8Khz Not Running at USB 3.0
sherifmagdy32
Re: Viper 8Khz Not Running at USB 3.0
Post by sherifmagdy32 » 20 Feb 2023, 23:28
nags92 wrote:
23 Jan 2023, 06:20
Vocaleyes wrote:
08 Jan 2023, 06:37
I’d like to chime in.
I run 8k in the usb 2.0 slot. 99% of games run it fine.
There is the issue of having discord running minimised which affects certain games like overwatch, but once FULLY terminated is resolved.
Am currently playing ffxiv, and it’s butter at 8k from the 2.0.
If you find a fix for the discord issue please let me know. It's been driving me mad, i was able to play Apex + CSGO at 8k with no stutter until the last week or so. :x
I do not if this fixes your problem but Nvidia fixed the issue with discord lowering the p state in the latest update so might try the latest update and hope it fixes your problem.
Arbybear
Post by Arbybear » 26 Feb 2023, 19:10
Has anyone had connection issues with their Viper 8K?
I've had mine for close to a year now, and recently it will randomly disconnect. Windows makes the "USB device unplugged" sound, no mouse buttons work, and the LED on the underside flickers. It will randomly reconnect, anywhere from seconds to hours to days later.
Windows 10 22H2
i7-8700k
Asus Prime Z370-A
DDR4-3200
I have tried:
- connecting the mouse to a different PC
- connecting the mouse to different USB ports (USB 2.0 and USB 3.0)
- connecting the mouse to a PCIe USB hub as the sole device
- updating mouse firmware
- updating Windows
- restarting PC
Nothing so far has helped.
