Disabling Write Combining on RTX 3000 GPUs?
RedFr4me
Re: Disabling Write Combining on RTX 3000 GPUs?
Post by RedFr4me » 08 Jan 2023, 12:54
mortez123 wrote:
08 Jan 2023, 08:59
BTRY B 529th FA BN wrote:
30 Jan 2021, 11:07
I'm sorry to hear that.
Does anyone know any other ways to get DisableWriteCombining to work on 3000 series GPUS? or is it just with the 3090?
Nvcleanstall have an option for it, did u check that?
Huh? I don't see any option to disable that.
mortez123
Post by mortez123 » 09 Jan 2023, 08:33
Huh? Me too 😂
There is an option to add hardware support to every driver version u want
assombrosso
Post by assombrosso » 09 Jan 2023, 19:36
What does it do
mortez123
Post by mortez123 » 11 Jan 2023, 07:39
assombrosso wrote:
09 Jan 2023, 19:36
What does it do
Told u, that option adds any hardware support to any driver version u want, which means if u can't install older versions which don't support newer hardwares, u can add that hardware in it's .inf file (for those who did it manually, just try with it too, maybe it does it differently). then u can install driver's like 441.41 for hardwares like 3090 which u couldn't before, then u can disable write combining.
grimmj6w
Post by grimmj6w » 22 Mar 2023, 22:42
Beating a dead horse here, but I’m still very interested in somehow making this work.
I’ve tried on my 3060, 441.41 will not install, at least with NVCleaninstall or NVSlimmer involved in some manner. I’ve tried modding the drivers INF then cleaning the bloat with either program. It will compile, but quits prior to installation. Next is to try just installing with the bloat and modding the INF.
kek224
Post by kek224 » 01 Mar 2024, 04:59
schizobeyondpills wrote:
30 Jan 2021, 12:41
1. patch the kernel to patch the driver call
2. sell nvidia gpus they suck. their tiled rendering mode is a joke on top of all other scams they deceive the consumer audience with more FPS which many many % (like 90%) never end up being sent on screen as actual frame but tiled through multiple frames. like prerendered frames scam.
If I'm not mistaken, tile rendering mode can be disabled in the registry:
HKLM\SOFTWARE\Microsoft\DirectX
D3D11_ALLOW_TILING = 0
D3D12_ALLOW_TILING = 0
