Atlas OS
Coldplayer
Atlas OS
Post by Coldplayer » 03 May 2023, 19:25
Hi just wondering if anyone here runs atlas OS and can compare it vs tweaking a system yourself. Just wondering if atlas is better at stripping stuff down vs when you manually run tweaks/disable services which lead to hundreds of event viewer errors etc.
KappaKaaNo
Re: Atlas OS
Post by KappaKaaNo » 04 May 2023, 00:53
Yes i'm using AtlasOS and if you're asking me its already tweaked but if you wanna touch on your own tweaks go for it, but its great for me i use it always when i wanna reset my PC.
(I'm 3k elo on faceit CSGO so that would give you a small indication personally for me its good)
Kyouki
Re: Atlas OS
Post by Kyouki » 04 May 2023, 04:23
Coldplayer wrote:
03 May 2023, 19:25
Not yet but heard plenty of good about it recently. I've mostly always tweaked my OS myself with stuff i'd find and retest overtime and usually find myself reinstalling every 2-4 Windows build releases and then disabling Windows Update to further stop bloating or cluttering up.
Each time with new discoveries as well as testing stuff a-new as it can differ per OS build.
However I may decide to automate this as I frankly don't have as much time to invest into it anymore as of late years.
vhagar
Re: Atlas OS
Post by vhagar » 04 May 2023, 07:55
I've tried GamerOS from the ntlite community. There is a quick start with this from Chris Titus. In my opinion this works much better than stripping things out yourself from a full install. YMMV.
https://github.com/ChrisTitusTech/ntlite-configs
Coldplayer
Re: Atlas OS
Post by Coldplayer » 04 May 2023, 10:18
Just got atlas and its very snappy, wondering what extra tweaks you guys apply?
InputLagger
Re: Atlas OS
Post by InputLagger » 04 May 2023, 12:09
Kyouki wrote:
04 May 2023, 04:23
Coldplayer wrote:
03 May 2023, 19:25
Use virtual machines with snapshots, then. 10 secs on nvme restoration back to previous state (any state, fresh,tweaked, not working)
Re: Atlas OS
Post by Chief Blur Buster » 04 May 2023, 19:03
Pre-tweaked operating systems such as GamerOS and AtlasOS are great timesavers for people concerned about spending 100's hours on tweaking. The professionals have iterated over tweaks all at once.
Coldplayer
Re: Atlas OS
Post by Coldplayer » 04 May 2023, 23:11
Just upgraded to atlas and the alt tabbing is really slow, does anyone know what could cause this? Quick google says focus assist but I can't find that option.
eropsy
Re: Atlas OS
Post by eropsy » 05 May 2023, 00:02
Coldplayer wrote:
04 May 2023, 23:11
start > settings > system > focus assist. So did u try game already on atlas was it worth?
kenj12345
Re: Atlas OS
Post by kenj12345 » 05 May 2023, 05:47
I'm sorry, but how to use nlite Gameros?
