Sorry by advance for my english.
Hello, I am a big fan of stroblight,
thank you very much for your works.
I have a little problem : I like use my screen : VG248QE with sharpness : 80
but when strobelight is on : sharpness is locked at 50.
Is it possible to change sharpness on my screen when strobelight is on ?
VG248QE sharpness locked at 50 when strobelight is on
flood
Re: VG248QE sharpness locked at 50 when strobelight is on
not sure what you mean by sharpness... do you mean contrast?
mrbao
Hi, thx fo your answer.
In my lcd monitor VG248QE, in OSD menu --> Image --> Sharpness.
When I put Strobelight on, my osd menu display : (3D-Mode) and most options are locked, I only can changed contrast and nvidia lightboost value. I want to change Sharpness value to 50 at 80.
Sorry for my english.
flood
are you using the english OSD?
I dont recall a sharpness setting...
mrbao
yes, I using the english OSD.
Falkentyne
You cant adjust monitor settings, except contrast, in lightboost mode. Applies to all LB monitors.
mrbao
thank you for your answer.
I very love strobelight, I always put strobelight on.
