Should you be worried about 1, 5, or 10 ms of input lag? Use Latency Split Test (LST) and find out!
tacocheese
Re: Should you be worried about 1, 5, or 10 ms of input lag? Use Latency Split Test (LST) and find out!
Post by tacocheese » 28 Dec 2022, 02:49
I barely passed 20ms and failed everything else pretty badly. 360hz monitor gsync and everything off 2k hz wireless mouse. The part driving me crazy is how I think I can tell the difference 100 percent. But then I'm wrong lol. I guess it's placebo. It also takes me forever to do each run i can't do it fast.
assombrosso
Post by assombrosso » 28 Dec 2022, 06:02
I don’t need to do this to know I sensitive to lag or not, I’ve tried it in csgo with all my tests and it’s night n day difference
MatrixQW
Post by MatrixQW » 01 Jun 2023, 11:51
Just got the VG279QM.
Also got a HyperX Pulsefire Surge mouse.
Decided to give this another try. I thought I was getting too old but seems I still got it.
The image is smooth, I did it super fast like in 6m.
mushi
Post by mushi » 13 Jun 2023, 16:11
MatrixQW wrote: ↑
01 Jun 2023, 11:51
Someone give this a man a job! Is anyone else able to detect sub-millisecond differences?
Rali
Post by Rali » 30 Sep 2023, 02:54
MatrixQW wrote: ↑
01 Jun 2023, 11:51
hey what monitor settings did u use on your 279qm to do this test man it’s amazing that u can do that with the vg I wanna know what was your settings for that test if u don’t mind
MatrixQW
Post by MatrixQW » 30 Sep 2023, 14:35
280Hz, OD80, Racing Mode, Shadow Boost 'off', Brightness 50, Contrast 80, VividPixel 0, Color Temp. User Mode R98 G99 B96
At 280Hz it has low input lag but I think that for games it might be better 240Hz because of faster response times and more room for the refresh cycle at 4,16ms instead of 3,57ms.
Rali
Post by Rali » 30 Sep 2023, 15:00
MatrixQW wrote: ↑
30 Sep 2023, 14:35
Oh ok thank you so much man I recently learned that gpu usage affect input lag in games is that true? I saw a video of it they said not to let it get 100% useage and they said when they test their GPU usage at 50% the input delay was lower do u know anything about that is it's true or not?
Post by jorimt » 30 Sep 2023, 16:43
Rali wrote: ↑
30 Sep 2023, 15:00
Yes, 99%+ GPU usage increases render queue latency, typically by around 1-2 frames. You can use Reflex to automatically prevent the GPU from maxing, or a manual FPS limit for the same purpose where Reflex isn't supported.
Displays: ASUS P27UCWM, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
Rali
Post by Rali » 01 Oct 2023, 03:42
jorimt wrote: ↑
30 Sep 2023, 16:43
Rali wrote: ↑
30 Sep 2023, 15:00
ok tysm I wanna set a fps limit instead but when I do so what gpu % should I settle with? Could I just capp it until the gpu stay around 90% and still get benefit of fps and everything? Also if I do decid to cap it do I turn of reflex? Or leave it on with the fps cap?
Post by RealNC » 01 Oct 2023, 03:46
Rali wrote: ↑
01 Oct 2023, 03:42
If the cap is reached, you're fine. If FPS falls below the cap, then you need to lower the cap more.
