Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
sherifmagdy32
Post
by sherifmagdy32 » 27 Jun 2023, 19:48
Anonymous wrote: ↑27 Jun 2023, 19:46
sherifmagdy32 wrote: ↑27 Jun 2023, 19:44
Anonymous wrote: ↑27 Jun 2023, 19:36
I was thinking, maybe you only have the script in a different folder or are executing from a different path and causing it to not find the Rw.exe.
I am running it from different path right but i already changed the path to match the one in the script
i put the tools folder next to the script and removed the back in the path it is actually working i even tried to manual create the dump file and it got deleted with the command at the end of the script
wait now even rw works on my machine but for some reason when i use the script it gives me the same error i used to have before it worked you using different version ?
You should download the whole repository folder and should work automatically. Every script is made to work with it. It has the latest portable version there.
Also know that GUI version cannot be running if you run the script.
There is something wrong with your rw version
i replaced it with the latest portable version and it now works without the rw error and this is the new error i am getting
sherifmagdy32
Post
by sherifmagdy32 » 27 Jun 2023, 20:19
Anonymous wrote: ↑27 Jun 2023, 20:03
sherifmagdy32 wrote: ↑27 Jun 2023, 19:48
There is nothing wrong with it. You can download and overwrite if you want, as long as it is the lastest x64 portable. It should be in the correct place that it is now.
I have just updated and improved the pathing of the script, as long as you have downloaded the gaming_os_tweaks whole folder, you should be able to execute it from anywhere and should work.
Before, from what I was testing, that is the exact problem that is happening over in your machine. Now it's fixed.
This is the output
sherifmagdy32
Post
by sherifmagdy32 » 27 Jun 2023, 20:24
Anonymous wrote: ↑27 Jun 2023, 20:23
sherifmagdy32 wrote: ↑27 Jun 2023, 20:19
This is the output
Lol, that is a different script, for interrupt affinity. I suppose it needs to be looked upon too.
sherifmagdy32
Post
by sherifmagdy32 » 27 Jun 2023, 20:30
Anonymous wrote: ↑27 Jun 2023, 20:28
sherifmagdy32 wrote: ↑27 Jun 2023, 20:24
Yeah, I dont know almost anything about powershell, but I wanted to automate these repetitive processes, so that's what I been doing.
Sorry about that it is 4:30 am here
i tried the right script giving the same last error
sherifmagdy32
Post
by sherifmagdy32 » 27 Jun 2023, 20:33
Yeah everything should be automated with scripts like you doing love the work keep it up
sherifmagdy32
Post
by sherifmagdy32 » 27 Jun 2023, 20:46
Anonymous wrote: ↑27 Jun 2023, 20:38
sherifmagdy32 wrote: ↑27 Jun 2023, 20:30
Haha, It's fine, at least there is feedback. That is a different error now, I suppose the value being fetched are not only numbers, that why the errors.
This is what I have been saying, instructions from djdallmann doesnt seem to include complete information, which is why I was not confident in the script being 100%. Like if there were a scenario with non-numbers. I suppose it will stay broken till someone who understand the domain part of it are able to fix or provide complete information. Maybe in a PR.
Oh well hopefully someone figure this out soon enough
Thanks for your time really appreciate it
sherifmagdy32
Post
by sherifmagdy32 » 27 Jun 2023, 20:50
Anonymous wrote: ↑27 Jun 2023, 20:48
sherifmagdy32 wrote: ↑27 Jun 2023, 20:46
Yeah, for sure.
btw I updated the interrupt affinity script, maybe it wont give those errors anymore.
oh cool
will check it out later tomorrow i can barley stay awake and will report the output
sherifmagdy32
Post
by sherifmagdy32 » 28 Jun 2023, 00:07
Anonymous wrote: ↑27 Jun 2023, 22:21
sherifmagdy32 wrote: ↑27 Jun 2023, 20:50
Yeah, for sure.
oh cool
Yeah, be sure to get latest update when you do.
I just had an idea about the non-numeric issue that was happening in the imod usb script, I built a solution, but again, it addressed the problem, but I dont have an intel to know that is going to the right values / address space, someone should test and someone with domain understanding should review and fix if not correct.
I know that for AMD it is not correct, since all I get are zeroes when checking manually.
But, at least now should be closer to be properly implemented.
Does this mean it worked ??
sherifmagdy32
Post
by sherifmagdy32 » 28 Jun 2023, 23:22
Anonymous wrote: ↑28 Jun 2023, 07:58
sherifmagdy32 wrote: ↑28 Jun 2023, 00:07
oh cool
It means it ran and without errors, so yes in a way, though now what remains is for someone to check/test if the implementation are correct or not (pointing/changing to the right value) and also figure out what to do for AMD.
Update:
BoringBoredom have been helping out in answering questions at
https://github.com/djdallmann/GamingPCSetup/issues/12
Now I am very close to fully understanding, maybe there is a possible solution to be built. But it's going to take more time.
Oh cool great work waiting for the final ver
Mimi123
Post
by Mimi123 » 17 Jul 2023, 16:14
Hello,
Thank you for your work, amazing stuff!
Although when running the script I get an error as enclosed. Do you have any idea where it comes from? My drivers are up to date
- probleme2.png (13.5 KiB) Viewed 10189 times
