Extended understanding of system timers in Windows.
serenamannesh
Re: Extended understanding of system timers in Windows.
Post by serenamannesh » 19 Jul 2023, 13:54
Just created an account to reply. I am having a strange issue, it appears that, no matter what value I input into it. Nothing changes. It no longer works for whatever reason. Is there an explanation for this?
Weissrolf
Post by Weissrolf » 23 Jul 2023, 07:08
It noteworthy that using "bcdedit /set disabledynamictick Yes" in Windows 11 seems to cause "% Processor Time counter" based measurements to be broken. As a result Task-Manager's "Details" tab, Resource Monitor, Process Lasso and Process Explorer report 100% all-core load as 3.125% (100 / 32 logical cores) and lower load is hardly measurable. I also totally expect any system/algorithm based on such a counter to fail working propelerly then.
dannyoceanic
Post by dannyoceanic » 23 Jul 2023, 12:31
Tiberiusmoon wrote:
12 Jul 2023, 12:29
dannyoceanic wrote:
12 Jul 2023, 08:58
Hey guys
Wanted to ask if any of you tried these changes and it made valorant run smoother ?
Tried a couple of tweaks so far and the game feels sluggish at some times :/
Post specs of your system including ram.
Rtx 3080
32 gb ram 2333hz 18CL
Ryzen 5 5800 X3d
2x M2 with 1 1TB, game is installed on one 1TB where the OS is located
850W be quiet
F1zus
Post by F1zus » 23 Jul 2023, 14:59
dannyoceanic wrote:
23 Jul 2023, 12:31
Tiberiusmoon wrote:
12 Jul 2023, 12:29
dannyoceanic wrote:
12 Jul 2023, 08:58
Hey guys
Rtx 3080
Ryzen 5 5800 X3d
850W be quiet
2333 cl18 is this a joke?
Throw out your RAM.
Your processor stutters because of crappy RAM, its pipeline is idle.
Your processor needs at least 3600cl16, ideally 3800cl14-14-14-14-28 cr1. Only in this case, you will experience a truly smooth game.
Remember a simple rule - for a perfectly smooth game you need perfect RAM with good timings and high frequency.
The second rule is to turn off all the energy savers in the BIOS. (c state and D3 and others).
dannyoceanic
Post by dannyoceanic » 24 Jul 2023, 07:45
F1zus wrote:
23 Jul 2023, 14:59
dannyoceanic wrote:
23 Jul 2023, 12:31
Tiberiusmoon wrote:
12 Jul 2023, 12:29
dannyoceanic wrote:
12 Jul 2023, 08:58
Hey guys
Rtx 3080
Ryzen 5 5800 X3d
850W be quiet
Throw out your RAM.
In this case, do you know whether 4x8 or 2x16 would be better ?
Ragerlis
Post by Ragerlis » 24 Jul 2023, 08:28
F1zus wrote:
23 Jul 2023, 14:59
dannyoceanic wrote:
23 Jul 2023, 12:31
Tiberiusmoon wrote:
12 Jul 2023, 12:29
dannyoceanic wrote:
12 Jul 2023, 08:58
Hey guys
Rtx 3080
Ryzen 5 5800 X3d
850W be quiet
Throw out your RAM.
2333 cl18 VERY likely means he just didnt turn on the xmp/doc profile and the motherboard is running the shittiest timings just to post.
No brand sells 2333 cl18 sticks, never did and never will.
Cl18 gives a tip its a 3600 ram actually, as cl18 is an usual timing for 3600 sticks specs.
noskill
Post by noskill » 24 Jul 2023, 13:30
sherifmagdy32 wrote:
15 Jul 2023, 05:10
Is there a way to force enable this on windows 10 or 11.
No.
F1zus
Post by F1zus » 24 Jul 2023, 17:38
dannyoceanic wrote:
24 Jul 2023, 07:45
2x16 is preferred. They are easier to overclock and have fewer compatibility issues. What swings FPS, then 2x16 show a little more FPS than 4x8.
dannyoceanic
Post by dannyoceanic » 25 Jul 2023, 00:57
F1zus wrote:
24 Jul 2023, 17:38
dannyoceanic wrote:
24 Jul 2023, 07:45
Thanks for the reply mate :)
I just ordered 3600mhz CL16 on 2x16 GB. I will check out if it works better then my current 4x8GB.
The90sPope
Post by The90sPope » 25 Jul 2023, 10:28
I have 5900X and for this CPU 4 dimms are better. As far as I remember, CCDs are related to that. Your 5800X 3D is 1 CCD, while my CPU has 2 CCDs.
I bought 2 kits G.Skill 3200 CL14 and overclocked it to 3800 CL14 and other timings are tighter than original. I had to increase voltage to 1.52V, but I slapped a cooler on the RAM so it's fine, it stays super cool.
Going from 3200 to 3800 made noticeable bump in performance in games.
“Death is a funny thing. Not funny haha, like a Woody Allen movie, but funny strange, like a Woody Allen marriage.”
― Norm Macdonald, Based on a True Story
