ntoskrnl.exe causing high DPC latency .
AlchemyTweaks
Post by AlchemyTweaks » 28 Jul 2023, 01:36
In vain I try to "fix" the high latency caused by the latency monitor when I make measurements. The main culprit is always "ntoskrnl.exe". I did a lot of research to find ways to reduce the high latency caused by the specific executable, but nothing I tried helped... So I would like to ask if anyone has found a way to deal with my problem. Thank you in advance for your time.
Weissrolf
Re: ntoskrnl.exe causing high DPC latency .
Post by Weissrolf » 30 Jul 2023, 13:01
That's not latency, it's processing time.
Post by Slender » 01 Aug 2023, 23:52
AlchemyTweaks wrote:
28 Jul 2023, 01:36
try ggos 0.9.4 powerplan (you can find it in ggos discord)
Weissrolf wrote:
30 Jul 2023, 13:01
why it generate dpc?
