This may solve the mouse acceleration problem that's plaguing you!
Syykfk
I am a player from China and I am currently a player of Valor Mythos 3.
I really like this forum and I have learned a lot so I would like to share my knowledge as well. One thing I would like to share is a registry change. It may fix your mouse acceleration/"floating" feeling problem.
First go to the registry and go to the following directory: HKEY_CURRENT_USER\Control Panel\Mouse
Create a new string value in Mouse and name it MouseAccel, set its value to 0 (as in Figure 1), then restart your computer and feel the difference it makes.
You can also change the value of MouseSpeed to -, the correct minus sign is to the right of the number 0 on the keyboard, or you can choose to copy my "-"." MouseSpeed" is the "Improve pointer accuracy" in the Mouse Properties in System Settings, 0=unchecked, 1=checked. fps gamers usually choose to leave it unchecked, and changing it to "-" in the registry will give you a different feel.
The above two changes do not conflict or oppose each other, they have a stacked result. Together they will affect the way you feel.
If you don't like the feeling, just delete the MouseAccel string or change MouseSpeed back to 0.
I assure you, this is not a placebo and it will definitely affect your mouse speed.
Another registry change has to do with display scaling. It is associated with (Figure 2) First go to the path HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\GraphicsDrivers\Configuration
There are many folders in there, click on Edit, then Find, type in Scaling and press F. (It's okay to delete the bunch, it will be generated automatically after reboot).
Modify only the values of the scaling ratio. Fullscreen=3, Aspect Ratio=4, No Scaling=2,0 are the ones I personally tested and downloaded the most.
This modification also affects the feel, it is recommended to backup the registry before modification. Just in case you can't adapt.
- Slender
Re: This may solve the mouse acceleration problem that's plaguing you!
Syykfk wrote: ↑28 Jul 2023, 08:57I am a player from China and I am currently a player of Valor Mythos 3.
hello! Where you find info about this reg?
also, you try to use another mousesmooth or just delete it?
- Slender
DisableMouseAccel(0).reg
DeleteMouseAccel(-).reg
MouseSpeed(-).reg
MouseSpeed(0).reg
Code: Select all
[HKEY_CURRENT_USER\Control Panel\Mouse]
"MouseAccel"="0"Code: Select all
"MouseAccel"=-Code: Select all
"MouseSpeed"="-"Code: Select all
"MouseSpeed"="0"- n1zoo
I didn't understand what I was supposed to do here. What should I delete and what should I change?
Syykfk
As far as I know there is very little information about this registry on the web, as I saw it on a Chinese website and documented it.Slender wrote: ↑02 Aug 2023, 00:43Syykfk wrote: ↑28 Jul 2023, 08:57I am a player from China and I am currently a player of Valor Mythos 3.
Please be assured that this registry change will only affect the feel of your mouse, if you find yourself unable to adapt, then change the value back to restore your original feel. This change will not affect the performance of your computer and will not lead to bugs.
BTW: "MouseAccel" only has a value option of 0. If you change MouseAccel to "-", it won't have any effect. Only 0 will trigger the usefulness of MouseAccel.
As for "MouseSpeed", please look at the following picture.
- Slender
changes in real time like change mousesmooth?Syykfk wrote: ↑02 Aug 2023, 06:02As far as I know there is very little information about this registry on the web, as I saw it on a Chinese website and documented it.Slender wrote: ↑02 Aug 2023, 00:43Syykfk wrote: ↑28 Jul 2023, 08:57I am a player from China and I am currently a player of Valor Mythos 3.
try delete mousesmooth
- Capture.PNG (19.18 KiB) Viewed 51833 times
Syykfk
Here's a video of it in action.
First reach the catalog.
Then use the search function. Find "Scaling" and change its value.
Then press "F3" to find the next "Scaling" and change its value again.
Until all the "Scaling" have been changed.
Then restart your computer.
Syykfk
I'm sorry, English is not my first language, so I can't understand you correctly.Slender wrote: ↑03 Aug 2023, 05:33changes in real time like change mousesmooth?Syykfk wrote: ↑02 Aug 2023, 06:02As far as I know there is very little information about this registry on the web, as I saw it on a Chinese website and documented it.Slender wrote: ↑02 Aug 2023, 00:43Syykfk wrote: ↑28 Jul 2023, 08:57I am a player from China and I am currently a player of Valor Mythos 3.
But if you're asking how to get back the old feel. Just remove "MouseAccel".
The registry change I proposed doesn't require deleting anything. Unless you want to restore the old feel, you don't need to delete anything.
Once you change the registry, you don't need to change the registry again if you change the mouse again. As long as the registry remains unchanged, it will continue to work. It affects the windows algorithm for mouse speed. Will not affect the mouse built-in driver.
Secondly, even if you turn on raw input in CSGO and Valorant, windows will still affect the mouse speed. What you end up with is a big mishmash of sensations. It's all kinds of superposition.
Supercutx
changing the scaling value from 4 to 2 changed the mouse feeling and it's definitely not placebo thanks so much
TN_fun
Most useless placebo commands i've ever seen.
