Im using stretched 4:3 1280x960 resolution in cs go. But when I change in my nvidia aspect setting to get stretched. It removes my VT1350 setting.. Any1 way I can use both vs 1350 AND stretched resolution?
Heres a video of what im talking about http://www.youtube.com/watch?v=ANYu-lNhmlc
Stretched 4:3 problem with VT1350 in cs go
Re: Stretched 4:3 problem with VT1350 in cs go
Is GPU scaling enabled? It should work with GPU scaling. (Well, in theory at least.)
Edit:
And get with the freakin' times already. 4:3 streched... Seriously
You're too used to a bad thing.
Edit:
well it makes things wider which some people find easier to aim at...
Well I used system restore to get rid of that custom nvidia profile.
And I find it easier to hit people with that resolution, things are bigger.
And yes I tried with gpu scaling, It didnt work
