How I fixed my input lag
ahead
Re: How I fixed my input lag
Post by ahead » 18 Sep 2023, 19:52
sndhck wrote:
18 Sep 2023, 01:16
My thoughts were why not try to connect headphones through external power and through an optical connector S/PDIF which is less prone to interference, and finally set the volume to 100 in windows, and adjust it with the DAC
https://en.wikipedia.org/wiki/S/PDIF
The receiver does not control the data rate.
That means it doesn't matter what DAC you use; this will change nothing in PC performance.
[email protected]
Post by [email protected] » 19 Sep 2023, 01:57
Can you take a photo of your setup please.
KingAzar
Post by KingAzar » 19 Sep 2023, 02:20
ahead wrote:
18 Sep 2023, 19:52
sndhck wrote:
18 Sep 2023, 01:16
so you mean he is experiencing mostly placebo effect?
ahead
Post by ahead » 20 Sep 2023, 03:43
yes.
imprecise
Post by imprecise » 20 Sep 2023, 20:23
Another source of this audio lag can be found in Windows settings:
