[For me at least] Possible Desync Fix
ixa
Post by ixa » 30 Sep 2023, 22:44
3rd update: Here is how I have it set up https://imgur.com/a/ErnqGJU The plug to connected to the wall, the right one is the PC power strip, there isn't any adapter cancelling ground because the same earth cable shown in the video was for that specific wallmount plug. But I removed it and instead used it to ground both the lamps and the stripped down coaxial cable, which then are jointed to the earth cable. Also if you notice, at minute 0:22/21 there is a slight interference when I get close in the video record
2nd Update: I put a coaxial cable, which I stripped off the plastic cover, leaving the metal shield exposed. Made it a coil and grounded it, this improved alot. I also put a plastic bag separating the both metal lamps and the coaxial cable from the top of pc case.
Also we made a conclussion that the lamp doesnt have to be plugged in, and according to chat gpt, grounding can help reduce the emi.
I also wanted to share my chatgpt conversation about emi stuff to help understand this post.
https://chat.openai.com/share/e82c2a6d- ... 4e119db592
I asked a lot of question related to emi, please Ignore the first two questions haha.
A post edit: I do not have any knowledge if the metal lamp must have a ground connection. I do not know if it wont work with or without it. Also I don't know if it makes a difference with the metal lamp plugged in or not, I also do not know if cancelling the ground of your pc makes a difference too. I did just as gengiskan said, like I explained in the post.
I haven't got the knowledge to try figure out what's going on, so feel free to to experiment. One tool it can be used for testing what it could be is an spectrum analyzer. My friend believes the lamp acts as some form of antenna by keeping the external signals not getting in to the pc. And not having it grounded increments the effect. But what do we know... it could be anything.
Hi there! hope y'all doing great.
First of all, ALL CREDITS GO TO GENGISKAN, an argentinean guy who tried EVERYTHING to fix it. So he started to realize the problem had to from an external source. And same like me, he was struggling with this problem for years.
Here's his YT channel: https://www.youtube.com/@adn23adn
Please keep in mind this is not intended for "heavy mouse feeling" or any input lag issues. Although it could possibly fix it (maybe yes maybe not). This goes to the desync in game, out of time with server, no reaction time, weird hitreg, etc.
The possible fix, that it also worked for me. The most strange of strangest fixes, but somehow with a bit of logic.
I will go straight to the point, As GENGISKAN said.
Just put a METAL nightstand lamp (Try it to be pure metal, not painted or anything.) over your PC CASE. This metal lamp must have an earth connection to it.
So, try to make joint on an earth cable from your wall plug or something and tack it down to the metal lamp. Also deny the earth connection from your PC by using an adapter.
For example, if you are using a power strip, try to get an adapter that cancels the earth connection.
And yes I know, this goes against the norm of eliminating EMI. Im confused too, you can try doing the same without cancelling the earth connection. And see if there is a difference.
Adapter example: https://imgur.com/a/uJrmz28
In my case, I have the monitor, router, and pc connected all to the same power strip, so all I did was to get an adapter that cancel the earth connection. Then with the ground cable, I have a copper bar buried in the backyard which I installed to give my house a ground connection, but failed to do it. So I used it as a ground connection for the metal lamp. By using the cable jointed to the copper bar jointing it with another earth cable and then tacking it to the metal lamp as shown in the image. The earth cable does not go to any electrical table or anything, from copper bar straight to metal lamp.
I do not know if the metal lamp has to be plugged in or not.
Here's an example https://imgur.com/a/BwRoiGW
The metal lamps do not have to be turned on. In case the light annoys you.
For me the difference was night and day... for example in BF4 Domination. I just couldn't play, I wasn't able to spawn, I wasnt able to run through the map that I was already getting shot after 2 seconds of spawned in. Bad hitreg, etc. But after putting in the lamp, i was able to win more 1v1 duels, hitreg was better, enemies dying faster, I feel more in sync with server, I dont feel behind everyone, etc.
Keep in mind difference may not come instantly, give it a time, like 1 match or 2. Then you will feel exactly if it fixed it.
Maybe the examples arent that great...
https://www.youtube.com/watch?v=kZbrGMxSB50 when it was bad
https://www.youtube.com/watch?v=rdWCIIRmFO0 after putting the lamp
From what I understand, this could be EMI in the air I can not understand how the lamp is acting as some form of antenna, as gengiskan said too.
Everythingblows
Re: Possible Desync Fix
Post by Everythingblows » 01 Oct 2023, 03:31
What kind of adapter do you use to plug into the power strip? What is this called
ixa
Post by ixa » 01 Oct 2023, 03:55
Everythingblows wrote: ↑
01 Oct 2023, 03:31
I updated the post with an image with the adapter. Here in Argentina we use the "Type I" plug. So I used a Type I adapter to Type C
kriegsnake
Post by kriegsnake » 01 Oct 2023, 05:19
ixa wrote: ↑
01 Oct 2023, 03:55
01 Oct 2023, 03:31
So basically I have to put metallic lamp on the case, ground it with the wall or the ground with the socket plug and give it a go?
ixa
Post by ixa » 01 Oct 2023, 05:29
kriegsnake wrote: ↑
01 Oct 2023, 05:19
ixa wrote: ↑
01 Oct 2023, 03:55
01 Oct 2023, 03:31
Yes! use the ground closest to you. And cancel the ground of your pc. (You can try without cancelling it too) but I would try cancelling it first. if you're using a power strip, just cancel the ground of plug of the power strip. I do not know if cancelling the earth of pc does a difference.
I updated the post explaining how I set it up in my case
Maybe what you can try is to, dissarm your wall plug, grab your earth cable, joint it to another earth cable and tack it down to the lamp, and then on the same wall plug connect your power strip ( where your pc and monitor are) cancelling the ground with an adapter
Derosa
Post by Derosa » 01 Oct 2023, 10:05
Great Discover =) do you think if i put the lamp on top of the case and ground it too a piece / bar of metal (not in the ground) will work? obv ill purchase the adapter to remove ground to power strip where is connected my pc .. another questio lamp need to be connected to plug or not tx =)
cybepine
Post by cybepine » 01 Oct 2023, 11:08
I would strongly advise against this advice.
It is never safe to cut the ground wire. If e.g. your GPU or power supply breaks down (short circuit or fault) you will highly likely get a lethal shock.
https://gopaschal.com/is-it-safe-to-cut ... und-prong/
ixa
Post by ixa » 01 Oct 2023, 13:46
Derosa wrote: ↑
01 Oct 2023, 10:05
There is a person who lives in 2nd floor appartment and doesnt have ground. he just put a metal lamp and for him it worked... weird.
So try just putting a metal lamp, and cancelling earth.
ixa
Post by ixa » 01 Oct 2023, 13:49
cybepine wrote: ↑
01 Oct 2023, 11:08
Yes ! as I said, this goes against the norm. This is why I don't recommend breaking the 3rd ground prong. And just testing it with or without earth ground. My believe is that by cancelling the ground prong, you make the metal lamp absorbe more "energy" o EMI. And deriving it to ground.
I have electrical leakage, so if I touch my pc case i get an electrical shock.. haha, but is minimal. Also I dont have ground in my house due to this beeing and old one
spkii
Post by spkii » 01 Oct 2023, 16:12
ixa wrote: ↑
01 Oct 2023, 13:46
Derosa wrote: ↑
01 Oct 2023, 10:05
My house is not grounded, with a lamp metal on top of PC will work only? Thanks.
