Headaches of the Asus PG27AQN from an Asus XG27AQMR owner
liquidshadowfox
Re: Headaches of the Asus PG27AQN from an Asus XG27AQMR owner
Post by liquidshadowfox » 18 Oct 2023, 13:17
nevermind, got it back again by changing scaling to "none" on display, for some reason my settings got changed to aspect ratio.
Post by jorimt » 18 Oct 2023, 13:20
liquidshadowfox wrote: ↑
18 Oct 2023, 11:38
I'll keep testing but man I'd hate to give up the 360 hz for valorant... Hopefully they roll out a new driver that fixes these issues in the future.
Again, try 8-bit instead of 12-bit. Worked for me, even before the driver update.
This is a 10-bit panel, so 12-bit will only add dithering anyway, and most games are still 8-bit as-is.
Displays: ASUS P27UCWM, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
liquidshadowfox
Post by liquidshadowfox » 18 Oct 2023, 13:57
Yea, I'm testing currently with 8 bit with DSC and 360 hz. As of right now it still has issues switching from ULMB 2 to Gsync with per game profiles. For example, I start with global Gsync profile, then hop on league and it switches to ULMB 2 after turning off the screen twice (ok I'll take it) but it works. Then when I end the game and go back to desktop there's like a 50% chance Gsync will re-engage or it'll turn white LED where it's just fixed refresh with ULMB 2 turned off.
Post by jorimt » 18 Oct 2023, 14:11
18 Oct 2023, 13:57
I wasn't referring to your ULMB2 switching issue, I was referring to the random black screens; 8-bit fixed that for me before and after the driver update.
As for seamlessly/automatically switching from ULMB2 to G-SYNC and visa-versa per game, good luck. That's never worked out on any monitor I've had them on, with or without DSC. I've personally always had to manually switch modes before launching a game every time I wanted to use either.
Closest I've gotten to "auto" between the two modes on the PG27AQN, is by enabling the ULMB2 option in the monitor settings when G-SYNC is disabled. That way, whenever I enable G-SYNC in the NVCP globally, ULMB2 disengages, and whenever I disable G-SYNC, ULMB2 applies again when in "Fixed Refresh" mode, which the NVCP defaults to when G-SYNC isn't enabled.
I'm honestly not even sure if the legacy "ULMB" (non-2) option in the NVCP even works properly for ULMB2 in all cases. "Fixed Refresh" should be enough.
liquidshadowfox
Post by liquidshadowfox » 18 Oct 2023, 14:41
The ULMB option in NVCP works and switches between Gsync and ULMB with less issues as long as you use the monitor at 240 hz with DSC turned off, the moment DSC gets turned on it starts having all these issues. Maybe I'll try using the fixed refresh option and see if that works better.
liquidshadowfox
Post by liquidshadowfox » 18 Oct 2023, 15:48
Do you happen to know what the "Soft controls" option exposed through DDC VPC codes is? Trying to programmatically change between two inputs but I can't seem to do so using my DDC app for that, only brightness and contrast so far.
The tip about using Fixed refresh works well, I haven't had any weird issues yet but I'll keep testing and see if it holds up.
Post by jorimt » 18 Oct 2023, 16:31
18 Oct 2023, 15:48
Nope.
18 Oct 2023, 15:48
Here's hoping it sticks then.
Post by jorimt » 19 Oct 2023, 22:06
18 Oct 2023, 15:48
Also, regarding my comment about bit depth, I rechecked the manual, and there's a reason we're experiencing issues on the PG27AQN when forcing higher than 8-bit at 1440p 360Hz; 10/12-bit apparently isn't fully supported in that scenario, so we're running out of bandwidth, even with DSC.
From the manual:
As such, HDR mode at 360Hz 1440p probably only achieves 10-bit via 8-bit + FRC.
Anyway, just a "good to know."
liquidshadowfox
Post by liquidshadowfox » 23 Oct 2023, 06:06
So far your suggestion is holding up. Yea I figured it must have been a bandwidth limit, I never thought I'd see the day I say "I wish this had hdmi 2.1" lol but here we are. Luckily I usually only use 8 bit colors anyways since most games I play don't really benefit or even support higher colors really and HDR is not worth it unless you are on oled or mini led with at least 1000 zones.
Post by jorimt » 23 Oct 2023, 16:16
23 Oct 2023, 06:06
Yup, pretty much.
