The first issue I've had and somewhat managed to resolve was the refresh rate was stuck at 30Hz, unless I created a dword:
Code: Select all
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000
DalSupportExternalPanelDrr=0
The next issue which I haven't been able to resolve is cursor skipping at higher refresh rates (~300+), and is the worst at 360Hz. I haven't noticed any frame skipping, yet the cursor doesn't get drawn every X amount of refreshes. This behavior did not exist on the Acer X25 360Hz, and this behavior does not exist when using the monitor with my iGPU. It happens on every OS I've tried (Win7, 10, and Troonix).
