Hi!
So I've noticed that my monitor (Samsung Odyssey G7) is skipping one frame in the frame skipping test unless i lower the refresh rate down to 190 Hz or lower. Is this normal behavior or is my unit faulty? Am i better of sticking with 240 Hz and the single skipped frame or should I lower my refresh rate down to 190 Hz?
Frame skipping at stock refresh rate
Re: Frame skipping at stock refresh rate
You have to rule out the browser first;senny22 wrote: ↑16 Nov 2023, 16:32Hi!
(A) Is the browser saying "VALID" in green continuously
(B) There are no red frametime spikes at https://www.testufo.com/animation-time-graph.
If (A) is yes, and (B) is yes, then your firmware might be faulty, but you have to be 100% sure that the frameskipping is not caused by the web browser. It was used to successfully detect firmware-based frameskipping bugs in the past on some models -- see viewtopic.php?t=3598
![Image](https://blurbusters.com/wp-content/uploads/2024/01/BlurBustersCollectionBanner-750x80.png)
