fluctuating mouse polling rate? FIXED
Skeezv
Re: fluctuating mouse polling rate? FIXED
Post by Skeezv » 17 Oct 2022, 14:21
Which version of windows are you using? As I understand it, these are commands related to changing the system clock. Will this have an effect on win11?
MontyTheAverage
Post by MontyTheAverage » 18 Oct 2022, 00:39
kPhobos wrote: ↑
17 Oct 2022, 08:59
Skeezv wrote: ↑
17 Oct 2022, 08:57
Please tell me the commands
Vocaleyes wrote: ↑
17 Oct 2022, 01:55
Also curious about those commands.
shebu wrote: ↑
17 Oct 2022, 01:22
kPhobos wrote: ↑
15 Oct 2022, 09:20
some commands i put into CMD
what commands did you use?
bcdedit /deletevalue useplatformtick
bcdedit /deletevalue disabledynamictick
*reboot pc after this, and ensure you run CMD as admin*
this put my fluctuation down from 500+hz, to about 20.
the following was put into CMD run as admin, which reduced it even further, to only 5hz max in fluctuation.
bcdedit /deletevalue x2apicpolicy
bcdedit /deletevalue tscsyncpolicy
bcdedit /deletevalue uselegacyapicmode
bcdedit /set nx OptIn
then add this one
bcdedit /set useplatformclock no
and reboot again.
after talking to him, he posted a thread about it aswell, referencing my forum post here to explain the issue
Twitter post: https://twitter.com/RealDrunKev/status/ ... 0894770176
Doesn't work on WIN11 or I never had these set in first place
kPhobos
Post by kPhobos » 20 Oct 2022, 07:20
MontyTheAverage wrote: ↑
18 Oct 2022, 00:39
kPhobos wrote: ↑
17 Oct 2022, 08:59
Skeezv wrote: ↑
17 Oct 2022, 08:57
Vocaleyes wrote: ↑
17 Oct 2022, 01:55
shebu wrote: ↑
17 Oct 2022, 01:22
kPhobos wrote: ↑
15 Oct 2022, 09:20
then add this one
and reboot again.
works on windows 11... i use win11 myself, if you didnt have any of the values in the first place, then this is not the fix you need, if you have the same issue as i had
kPhobos
Post by kPhobos » 20 Oct 2022, 07:22
Skeezv wrote: ↑
17 Oct 2022, 14:21
these are related to some system clock stuff, i use win11 myself, and could already feel a huge improvement just by deleting the first two values. i believe most of these values are added through "system optimization" videos on youtube, or through someone who does it as a paid service.
the instant i restarted my pc after deleting the first two values, i could immediately feel a huge difference
SvenL
Post by SvenL » 20 Oct 2022, 08:51
kPhobos wrote: ↑
20 Oct 2022, 07:22
Thanks for sharing the commands, will try these later. I just tested my mouse and it also has a fluctuating mouse polling rate. Damn :(
Do you think that if the polling rate is not constantly 1000Hz, this has a noticeable negative effect during aiming? Especially with smooth tracking, i.e. with slower movements (shots miss etc.) or is that something that can be ignored for this area?
TN_fun
Post by TN_fun » 20 Oct 2022, 15:30
kPhobos wrote: ↑
17 Oct 2022, 08:59
What's the point in 500 Hz, almost no one uses it. How about 1000Hz?
Vocaleyes
Post by Vocaleyes » 21 Oct 2022, 00:19
TN_fun wrote: ↑
20 Oct 2022, 15:30
kPhobos wrote: ↑
17 Oct 2022, 08:59
500 does and always has felt better than 1000.
On paper 1k should be better and visually it is, but 500 felt like it had a better balanced x&y.
No idea why.
xShino
Post by xShino » 19 Dec 2022, 12:35
then add this one
and reboot again.
Sorry to revive this thread. But am I understanding you correctly, that your Polling Rate does not go under 450 HZ while using 500 HZ when moving your mouse very slow? I don't understand how that's possible.
EvilPlaty
Post by EvilPlaty » 18 Sep 2024, 23:26
So does it mean that if my polling rate is unstable, my aim will also be inconsistent? really looking to fix this.
