G-SYNC works in windowed mode even disabled and causes stuttering/flickering
panicaz
Re: G-SYNC works in windowed mode even disabled and causes stuttering/flickering
Post by panicaz » 30 Nov 2022, 09:40
imprecise wrote:
29 Nov 2022, 15:31
I have experienced this as well, but toggling G-Sync on and back off has fixed it for me.
This was the first obvious solution I tried.
Today I installed old Windows 10 1909 on a separate SSD and G-sync works totally fine. No VRR trigger in windowed mode if disabled in NVCP. So the problem is most likely in Windows 10 updates somwere between 1909 and 22H2 version.
Any thoughts about fixing it on modern version of Windows 10?
Dell S2716DG 144hz | R5 5800X3D | RTX 3070 | 16*2gb 3600mhz cl17
Kyouki
Post by Kyouki » 30 Nov 2022, 10:00
Hmmm maybe full-screen optimizations stuff. Though I am not entirely sure how this works yet.
Just happen to know around those versions that got introduced.
Post by jorimt » 30 Nov 2022, 10:14
panicaz wrote:
30 Nov 2022, 09:40
imprecise wrote:
29 Nov 2022, 15:31
May or may not be MPO-related (effectively makes some windowed apps act more like exclusive fullscreen when focused):
https://nvidia.custhelp.com/app/answers ... er-version
Nvidia offers a regedit to disable MPO:
https://nvidia.custhelp.com/app/answers ... /a_id/5157
You can attempt the regedit on your original drive (containing the newer version of Windows) to see whether that resolves your particular issue.
Kyouki
Post by Kyouki » 30 Nov 2022, 10:24
jorimt wrote:
30 Nov 2022, 10:14
panicaz wrote:
30 Nov 2022, 09:40
imprecise wrote:
29 Nov 2022, 15:31
Read about this about a week ago, though didn't consider this one as a valid solution -- did this change per those versions? (if you know)
Post by jorimt » 30 Nov 2022, 11:04
Kyouki wrote:
30 Nov 2022, 10:24
MPO support for Nvidia GPUs was introduced in driver version 461.09. I don't know what Windows 10 version introduced it at the OS-level off-the-top-of-my-head though.
Again, it may or may not be the culprit, but worth a shot.
panicaz
Post by panicaz » 30 Nov 2022, 11:05
jorimt wrote:
30 Nov 2022, 10:14
Yep! This works. Disabling MPO fixes stuttering and flickering with G-SYNC enabled.
Thanks you guys for help!
Post by jorimt » 30 Nov 2022, 11:42
panicaz wrote:
30 Nov 2022, 11:05
Nice.
Kyouki
Post by Kyouki » 30 Nov 2022, 17:27
jorimt wrote:
30 Nov 2022, 11:42
panicaz wrote:
30 Nov 2022, 11:05
Nice.
Cool, thanks.
Also cool it worked out. I'll remember that one for nexttime someone has the issue.
progamingnoob
Post by progamingnoob » 02 Dec 2022, 03:47
panicaz wrote:
30 Nov 2022, 11:05
jorimt wrote:
30 Nov 2022, 10:14
- same this regedit just fixed everything, my mw2 benchmark score didn't change, my 3080 is cranking out frames in mw2 again, almost consistantly 277 fps the whole time with no stutters or dips (im using 3x monitors btw idk if that matters)
- also just googling mpo it seems like the amd guys are using this tweak a lot
Eian
Post by Eian » 12 Jun 2026, 16:36
Ok, so I just found a really strange workaround for this issue without disabling MPO.
I’m using two monitors with G-SYNC set to “fullscreen apps only,” yet I still get the G-SYNC indicator on my main monitor
when using windowed apps like Viber and a few others.
Both monitors are the same 180Hz G-SYNC compatible models, but this only happens on the main one.
Now here’s the weird part:
If I go into the NVIDIA Control Panel, add the Viber app, change Monitor Technology to Fixed Refresh Rate, click Apply,
and then switch everything back to Use Global Setting (exactly as it was before), G-SYNC stops activating.
I have no idea how that even works, but I’m guessing this changes additional hidden driver flags
beyond just Preferred Refresh Rate and Vertical Sync that aren’t shown in the Control Panel.
If I remove the app from the list, the issue comes back again..
NVidia Control Panel.png (91.71 KiB) Viewed 1035 times
