yes, feels worse. Costs me many fpsBTRY B 529th FA BN wrote: ↑21 Feb 2023, 16:42Have you tried disabling both CPPC and CPPC preferred cores, + setting your Interrupt Steering to Any Unparked Processor, + disabled Processor idle, all at the same time??
pls help me to fix my csgo problems I have for years
paddyhhh
Re: pls help me to fix my csgo problems I have for years
paddyhhh
Maybe will give it some try.Bloedboer wrote: ↑21 Feb 2023, 15:28Try the build mentioned here: https://www.reddit.com/r/Windows11/comm ... _in_games/
It fixxed al csgo input lag i had. Bad thing is you can’t use Faceit ac with insiders build
But however I do not think it makes any difference since I tried 1000,2000,4000,8000 hz, feels nearly the same.
Since it is fixed in the night, I dont think the Problem is the PC itself.
Funny: Mouse feels the same when I play with power plan energy save.
I have 150fps instead of stable 350+ but mouse feels the same.
- Tiberiusmoon
Ill post some suggestions, I understand that sometimes what anyone suggests maybe a reworded version of whats already been done so ill just post a list.
Also, these are various suggestions I know to reduce latency, its hard to say what specifically is causing your issue.
-Double checked this is disable in your power save settings: https://i.imgur.com/r8zfQer.png
-Assigned the process "csrss.exe" to realtime.
-Deny csrss and the game from using core 0.
-Deferred procedure call (DPC) or interrupt handler for physical devices: https://www.youtube.com/watch?v=XRIvSzLY4DQ
-This is a guide to further reduce input lag, this won't resolve your issue as its tweaking default stuff but if your interested in tweaking, go for it: https://www.youtube.com/watch?v=kVHiSsZhR_c
paddyhhh
Thanks for your post.Tiberiusmoon wrote: ↑22 Feb 2023, 17:43Ill post some suggestions, I understand that sometimes what anyone suggests maybe a reworded version of whats already been done so ill just post a list.
Funny, already did every single one. Yep its some years already...
- Tiberiusmoon
Dang, I would suggest going onto the LTT forums to broaden your search for a solution, I don't think many people here will know as much about networking issues.paddyhhh wrote: ↑22 Feb 2023, 18:46Thanks for your post.Tiberiusmoon wrote: ↑22 Feb 2023, 17:43Ill post some suggestions, I understand that sometimes what anyone suggests maybe a reworded version of whats already been done so ill just post a list.
- imprecise
I noticed a few things reading through your post:paddyhhh wrote: ↑20 Feb 2023, 14:26game:
competetive cs go (problem is slightly better at Valorant)
problem:
A short stutter/lag/desync mainly when shooting at enemy, impossible to spray
Mouse floaty, feel of input lag
delayed sound
In general I think the game is playable I still got lvl10 faceit, but I have these phases when its perfect. Its a completely different game.
BUT:
at night my game is always perfect (around 2 am-5am)
When the game is perfect, it does not matter what settings I change, the game stays perfect. The monitor colours get much stronger, it is very easy to see enemies.
Once in a while, like all 3-4 weeks the problem fixes itself without any changes. That can be 1 hour or 3 days. Then slowly creeps back.
After joining a server, game is always for 15-20 sec perfect
Perfect means: The game is just so much faster, no stutter, no input lag, real 390hz, perfect mouse feeling.
monitor colors getting stronger. Have you disabled any power-saving features in the monitor? Does it have a dynamic brightness feature, causing the monitor settings to change automatically?
stutter lag/input lag. You could record gameplay during day and night and compare the net_graph numbers. 5 minutes during each time should be enough data.
Your issue sounds likely to be: Memory, network card, sound card related. Have you tested your overall system performance with something like Passmark? Delayed sound makes it very likely to be audio or network related. Since it's only during day and not at night, most likely to be network.
Network:
What is your Rate in game? You shouldn't be using the highest 700k rate with your connection, and 500k might still be too high.
Do you use other devices on the internet during the day? It isn't much bandwidth and will cause congestion problems sharing it with any other devices. Example: Streaming video or browsing the web on a cell phone.
-Use QOS to eliminate bufferbloat
Have you tested without QOS? It often introduces problems. Windows also has some QOS settings to prioritize certain apps like Skype and Discord.
Windows Update reserves part of your network connection and also is set to share updates by default, which could cause this during the day more than at night. There are a couple Windows settings for this you can change if you haven't already.
Your MTU might be set too high in Windows, causing packets to be resent frequently, making the problem worse during network congested hours.
You can test your connection to the server with Pingplotter (don't share the info, it will dox you), but you need to go into settings and change to UDP packets. If you test this, do it during lag-free and lagged times for comparison.
More general things to check (not night/day specific):
AMD CPU. I've noticed with AMD CPU, any application above normal priority will negatively affect the game (Windows dwm, Discord, Steam, browsers, etc). Are you using something like Process Lasso to ensure the game is highest priority, and other apps aren't set to high? I have seen many other people mention the game shouldn't be on CPU 0 as well.
Have you combed through Device Manager to make sure power saving is disabled for every device? There is a security feature in the AMD chip that has power-saving on by default. download/file.php?id=3095
2023 Esports Guide: forums.blurbusters.com/viewtopic.php?t=11799
Windows 10 Esports Guide: forums.blurbusters.com/viewtopic.php?t=10724
- Tiberiusmoon
Oh yeah, one consideration I forgot to mention:
Have you made sure your power cables are routed seperately from all the other cables such as your mouse?
blackmagic
its me blackmagic again...
i was following everything what happens here and i want only say 1 thing.
your issues are connected to network and your providers and location from where you connect to the servers...
elecricity is bullshit and chief is right that 99% cases are not connected to emi or electricity.
everything said.
we need to focus on providers and location from where players connect to server and how it all gets handled at the connect point...
something here is happening and going very very wrong for many players...
everything said.
assombrosso
Indeed , I don’t think is the only fix for my case. It’s servers and net code and ISP. I’ve seen some streamers have flawless gameplay that changes to laggy from time to time.blackmagic wrote: ↑23 Feb 2023, 08:11its me blackmagic again...
everything said.
Hiddenbars
Chief Blur Buster wrote:*** WARNING WARNING WARNING ***
One forum member reported a potential hard disk wiper.
Be very careful where you download your software.
Some of them is legitimate NVIDIA-compatible software and another is a hard disk wiper (virus/trojan/malware)
So when you follow tips like these, please research separately and correctly download the correct software from authorized sources reviewed and recommended by multiple people. One identical package is safe and another near identical package is very dangerous! never google for executables to download, and never follow advice to google for executables -- always track them down separately to their most authoritative websites or from much more highly trusted websites (e.g. PC Gamer) that has already vetted a safe source.
Always research fully to get the proper, original authoritative sources of packages such as NVInspector or NVCleanInstall -- these are legitimate packages but some malware vendors have created malware versions of these at different "clone" websites and then sometimes hijacked the Google SEO to rank higher than the legitimate executables. Accidentally downloading software (etc) from the wrong or compromised website = your disk could be wiped by a trojan
- I found 1 fix for this but it will only work if you are lucky!
- Can't guarantee anything!
Just wanna share what I know, so we can put this huge garbage can of problem to rest.
Im gonna type exactly what I did. In this order from up to down.
Install Nvidia driver through ' nvcleaninstall after that boot into BIOS.
You'll have to remove fast boot, and even the memory fast boot from the BIOS.
Start up you computer, so It won't log anything after that.
Install MSI afterburner, overclock your GPU with higher voltage.
(Mine was set to 975 mv) I locked it and had kombuster running. After that reboot.
Now head over to ' Interrupt Affinity Policy Tool,
This is the CPU order I had, move them if possible to same CPU:
CPU 3 - HD_AUDIO_CONTROLLER_(CPU_3)
CPU 4 - INTEL_UHD_GRAPHICS_750_(CPU_4)
CPU 5 - INTEL_PEG60_4C09_(CPU_5) and STANDARD_NVM_EXPRESS_CONTROLLER_(CPU_5)
CPU 8 - USB_XHCI_COMPLIANT_HOST_CONTROLLER_(CPU_8)
CPU 11 - INTEL_ETHERNET_CONTROLLER_1225-V_(CPU_11) and INTEL_PCI_EXPRESS_ROOT_PORT#5_43BC_(CPU_11)
CPU 13 - INTEL_PEG10_4C01_(CPU_13) and NVIDIA_GEFORCE_RTX_3070TI_(CPU_13) and NVIDIA_HIGH_DEFINITION_AUDIO_(CPU_13)
Try this order if you have less cores then try to make it work at your end. (CLONE ORDER)
Now Restart PC.
Now proceed to ' MSI_util_v3.exe , and check the new PCI mode you made, make sure you check everyone
and don't miss out. Restart PC.
Now head over to MSI Afterburner again, and run a stress test through Kombuster about 4 min.
Its gonna sound really annoying now, but head over to Parted Magic Secure Erase,
download and make it bootable through rufus usb tool.
Run the USB and use the number 1 option, other words just press enter inside Parted Magic Secure Erase.
When you are inside Parted Magic Secure Erase, head over to secure erase.
Now select your SSD, in my case M.2 drive,
Important -> press on VERIFY before you secure erase, it takes 1 min longer. (You are done!_)
When I was there, I had one USB laying around with windows, and I installed it.
And everything worked after that, no sluggish mouse, no slowing down, it all worked somehow,
trust me never been happier.
I think the issue here is that something in the system needs hard reset, not even the CMOS could help me with that.
Could be electricity damage related or something with GPU and the PCI slots working with the CPU, my speculations.
I really hope this could help someone out there, anyways, please don't do these steps without any form of knowledge.
If you guys find an easier solution, just share.
Off topic.
Have a new YouTube channel: ' HiddenTweaks ' , would appreciate you guys following me there.
Anyways hope this works!
Caution as I mentioned before don't try this without any form of knowledge.
