Mousetester graphs
Re: Mousetester graphs
Post by Slender » 16 Aug 2023, 09:05
viewtopic.php?f=10&t=9663
1) Try to reinstall windows (revi/ggos)
2) Use first default bios / use latest default bios (if same, setting up new bios with xmp only)
3) Full configure / default bios (set 1 settings - reboot to OS - test)
4) If fresh windows is ok just install gpu driver via nvcleaninstall
5) Disable unused devices (audio/usb/controllers/etc)
6) ALL devices in msi mode
7) Interrupt affinity - usb core 2 or 5 (or def 0) / gpu on 3/4 - (disable e-cores in OS (bcdedit /set numproc 8) / disable HT)
8) TEST without GPU driver (disable in dev.man) - compare results.
9) Use Diff controller for mouse (also if you have intel you can use internal usb 2.0 GL controller - just connect mice to usb 2.0 on pc case)
10) CSRSS - HIGH / REALTIME PRIORITY
11) Lock gpu freq (regedit / nvcpl)
12) If can update gop on gpu / or use CSM mode if you have bad-uefi on gpu / mb
13) XHCI HAND-OFF - disable
14) USB legacy - enable (default) / disable - specific settings by every board.
15) try to use ggos powerplan + setting interrupt steering (any processor / core 0 / core 1) + combine it with affinity gpu / usb / no affinity
16) Disable usb interrupt moderation (find script on this forum)
also, for me, on all my systems ggos 0.9.4 is most stable windows to detect bios issue with mouse or like that.
Code: Select all
bcdedit /deletevalue useplatformtick
bcdedit /deletevalue useplatformclock
bcdedit /deletevalue tscsyncpolicy
bcdedit /set disabledynamictick yes / bcdedit /deletevalue disabledynamictick
F1zus
Post by F1zus » 16 Aug 2023, 13:20
Slender wrote: ↑
16 Aug 2023, 09:05
Code: Select all
I did all these steps and more. My mouse is still unstable at 4000-8000Hz. There are some strange jumps up to 200000Hz.
It seems to me that either the mouse tester program does not quite correctly measure the polling frequency, or the motherboard controllers are weak and do not allow working with a high polling frequency.
By the way, about step 7. You say 2 or 5 core, but on a windows system 5 core = 4 thread. Cores go 0, 2, 4, 6, 8, 10, 12 (total 6 cores and 6 threads, cores are shown as even numbers).
My mouse is on 2 cores, the keyboard is on 8, I tried to change it, there is no difference.
Post by Slender » 16 Aug 2023, 13:27
F1zus wrote: ↑
16 Aug 2023, 13:20
Slender wrote: ↑
16 Aug 2023, 09:05
Code: Select all
i have only p-cores, nothing more.
combine affinity, i have same issue.
image (1).png (162.11 KiB) Viewed 7303 times
widow13
Post by widow13 » 16 Aug 2023, 13:39
Slender wrote: ↑
16 Aug 2023, 13:27
F1zus wrote: ↑
16 Aug 2023, 13:20
Slender wrote: ↑
16 Aug 2023, 09:05
Code: Select all
So your problems were fixed when you achieved a good mousetester graph ? Because I've been really wondering if mousetester is the correct tool to look at for me to get it fixed.
Thanks for this! I'm gonna it a try and hope for the best.
Mr_Mir
Post by Mr_Mir » 17 Aug 2023, 10:01
Slender wrote: ↑
16 Aug 2023, 09:05
Code: Select all
Hello, could you share a link to script - disable usb interrupt moderation. А quick search on the forum did not return any results or I was looking in the wrong place. The only thing I found is this post.
https://github.com/BoringBoredom/PC-Opt ... %20imod.md
This is it?
Thank you.
widow13
Post by widow13 » 17 Aug 2023, 10:08
Also do u recommend buying a pcie usb card ? Would it help ?
and if yes. Any good recommendations ?
Post by Slender » 17 Aug 2023, 11:21
widow13 wrote: ↑
17 Aug 2023, 10:08
im tried only via and nec (v1/v2) 3.0 board.
All have jitter, it good controllers to move dac, mic, keyboard, and use motherboard usb for mouse only.
But im use usb 2.0 pci fard on mcs9990 chip. It dont have msi mode and have more isr then usb 3.0 pci card 5-10 vs 0.5-1 but this controller have clean graphs + no jitter.
+ (im not sure) mcs9990 dont have interrupt moderation.
widow13
Post by widow13 » 17 Aug 2023, 12:17
Slender wrote: ↑
17 Aug 2023, 11:21
widow13 wrote: ↑
17 Aug 2023, 10:08
Hmmm thanks I might try that out.
Even removing every single usb and leaving only the mouse doesn't get me stable polling.
Is it better to use chipset or cpu usb ports ?
Did your problems get resolved when u achieved perfect mouse graph ?
Post by Slender » 17 Aug 2023, 12:19
widow13 wrote: ↑
17 Aug 2023, 12:17
Slender wrote: ↑
17 Aug 2023, 11:21
widow13 wrote: ↑
17 Aug 2023, 10:08
no, my gameplay is very smooth, but i have same weird responce and feel like my mouse is heavy.
widow13
Post by widow13 » 17 Aug 2023, 12:21
Slender wrote: ↑
17 Aug 2023, 12:19
widow13 wrote: ↑
17 Aug 2023, 12:17
Slender wrote: ↑
17 Aug 2023, 11:21
widow13 wrote: ↑
17 Aug 2023, 10:08
Eh, I have the same issues,feels like desync too. I guess achieving perfect graphs is not guaranteed to solve my issues, might have to try my pc on different house too.
