I'm VALO pro, still can't figure out what I'm doing wrong or what is going on!
phaze
Re: I'm VALO pro, still can't figure out what I'm doing wrong or what is going on!
Post by phaze » 06 Sep 2023, 01:06
mago wrote: ↑
05 Sep 2023, 16:30
turn on gpu msi mode + undefined
bcdedit:
tscsyncpolicy Enhanced
useplatformclock No
disabledynamictick Yes
and with Intelligent standby list cleaner ISLC
set timer to 0.5ms
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\kbdclass\Parameters]
"KeyboardDataQueueSize"=dword:0000003c
if not high-end cpu set 40dec
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\mouclass\Parameters]
"MouseDataQueueSize"=dword:00000014
I really tried this, and I have 3070 which has MSI mode enabled by default. and still no hope.
phaze
Post by phaze » 06 Sep 2023, 02:34
delve wrote: ↑
05 Sep 2023, 15:07
test his out also
https://www.youtube.com/watch?v=hN-H2xSSEJA
Well, this is weird, I went to this guy's previous video, and he said switch to 1600x900 to fix the issue, I did that and indeed the game felt much smoother and the kills are instant, instead of that delayed headshot animation/delayed killmark.
wow!
eropsy
Post by eropsy » 06 Sep 2023, 04:23
Tiberiusmoon wrote: ↑
05 Sep 2023, 14:08
Try:
bcdedit /set tscsyncpolicy enhanced
Download https://github.com/SanGraphic/QuickBoost and click the following:
Enable Exclusive Full-screen & disable Xbox Gamebar.
Disable mouse acceleration.
checked download link for quickboost and its says malicious is that false positive? https://www.virustotal.com/gui/url/6334 ... 4f8c9166c0
Tiberiusmoon
Post by Tiberiusmoon » 06 Sep 2023, 08:13
eropsy wrote: ↑
06 Sep 2023, 04:23
05 Sep 2023, 14:08
Try:
Ah false positive, the kurd link is from within the description but you can get the github download from the releses section on the right side.
https://github.com/SanGraphic/QuickBoos ... kBoost.exe
To clarify: https://www.virustotal.com/gui/url/ac6d ... bb8372b612
eropsy
Post by eropsy » 06 Sep 2023, 09:45
06 Sep 2023, 08:13
eropsy wrote: ↑
06 Sep 2023, 04:23
05 Sep 2023, 14:08
Try:
Thanks for clarification
deama
Post by deama » 06 Sep 2023, 15:25
There was a few posts by the chief on a somewhat detailed overview of how the netcode is handled in the background and how shady it is.
I remember him mentioning wierd stuff like the match making balance essentially adds in "hidden" lag to you vs others, maybe in this case you're account has been flagged for it or something. This stuff is pretty shady.
imprecise
Post by imprecise » 06 Sep 2023, 19:49
Did this just start happening? I recently found my power profiles broke and kept returning to balanced, gsync turned itself on with no indication in nvidia nor the monitor. Game mode turned on by itself, and HAGS enabled itself. I found all this when I was testing different RAM timings. I think it's connected to a Windows update at the end of August, perfectly timed for the release of the CS2 beta.
TrapKX
Post by TrapKX » 27 Oct 2025, 08:58
phaze wrote: ↑
06 Sep 2023, 02:34
delve wrote: ↑
05 Sep 2023, 15:07
test his out also
wow!
Have u found a fix or yet because ive had this issue for years and im losing my mind I even bought a whole new pc same problem yesterday i played on tournament client and the game felt smooth as hell
