Asus Rog Strix 24.5 XG259CMS
Xndrei
Re: Asus Rog Strix 24.5 XG259CMS
Post by Xndrei » 15 Feb 2025, 10:14
How many years ( approximately ), will xg259cms last? I got a nightmare from the VG249QM1A which only lasted 1 year even though i took care of it well.
synthMaelstrom
Post by synthMaelstrom » 15 Feb 2025, 16:16
Xndrei wrote:
15 Feb 2025, 10:14
It's a futile question. Look up the concept of bathtub curve and then... hope for the best? That's how it's always been with tech, more or less.
Display: ASUS XG259CMS OS: Windows 11 Pro Case: Fractal Design Meshify C PSU: Fractal Design Ion+ 760p MB: ASUS X370 Crosshair Hero VI CPU: Ryzen 7 5700X3D w/Deepcool Assassin 4S GPU: Sapphire Pulse RX 6800 XT RAM: 4*8GB Patriot Viper Steel 3733MHz CL16 SSDs: 1TB Crucial P5 (OS), 3.5TB combined SATA SSDs Keyboards: Razer Tartarus Pro, Vortex Race III Mice: Xtrfy MZ1, Glorious Model I, Sound: ATH-M50X
Doogydog
Post by Doogydog » 16 Feb 2025, 12:54
Xndrei wrote:
15 Feb 2025, 10:14
Don't buy it, I bought it to compare it with my vg259qm and the monitor has an excellent performance but all benefit is ruined by its VERY aggresive coating (is like oil layer effect), i think other xg models from 2024 suffer from this, at least this one and the xg27acs.
If you play with the screen near your face, like me, is UGLY, skip this model if you want ir for competitive.
synthMaelstrom
Post by synthMaelstrom » 16 Feb 2025, 16:33
Doogydog wrote:
16 Feb 2025, 12:54
To be honest I noticed that too after I switched from my VG279Q, but after a while it's not that bad at all, although my daily driving brightness on it is 100nit (about 21 brightness), so I got used to it by now.
cvijet
Post by cvijet » 24 Feb 2025, 18:17
I just got the XG259CMS and ive been experiencing some black lines in the monitor sometimes is anyone experiencing that
synthMaelstrom
Post by synthMaelstrom » 02 Mar 2025, 16:35
cvijet wrote:
24 Feb 2025, 18:17
Describe it in more detail, with pictures, if you can.
cvijet
Post by cvijet » 04 Mar 2025, 10:32
its small black lines around the letters
synthMaelstrom
Post by synthMaelstrom » 07 Mar 2025, 03:25
cvijet wrote:
04 Mar 2025, 10:32
These are Windows ClearType artifacts. I've mentioned this quirk in my post about the monitor previously, and have since not found a reliable enough of a fix other than disabling CT entirely or setting it to Grayscale via BetterClearTypeTuner. One other option is MacType, which I have got to work flawlessly for a while, but I only achieved this with a peculiar sequence of settings that I applied in a certain order which I have since forgot because it didn't stick as the lines came back after a reboot. It went something like disabling ClearType first, then enabling MacType, turning off the main monitor, then unplugging the second monitor... I'll come back to solving this issue sometime in the future, hopefully, but so far it is what it is.
cvijet
Post by cvijet » 09 Mar 2025, 19:19
so i got no problem in my monitor?
Hoterqq
Post by Hoterqq » 30 Mar 2025, 05:19
kyube wrote:
10 Sep 2024, 12:46
gigapiga wrote:
07 Sep 2024, 20:51
Hey guys this is my first post here. Building a new pc which meant upgrading my old monitor. I was on a AOC 144hz VA panel and I just ordered this monitor. Can't find many reviews anywhere. Was wondering if anyone knew the best settings for it? I play mostly competitve games like Valorant and such. The 310 hz caught my attention, but I know sometimes the overclock can cause more issues than benefits.
https://www..com/video/BV1wU411S7tY/ @ 03:12 should be what interests you.
Does it mean input lag or reponse time ? cuz if it`s response time looks like it better than on monitors like AW2523HF and XG259QNS ?
