Audio and Video Out of Sync
Unreazz
Re: Audio and Video Out of Sync
Post by Unreazz » 10 Jan 2025, 17:19
Asesino34 wrote: ↑
10 Jan 2025, 16:44
bwainzz wrote: ↑
10 Jan 2025, 11:16
Asesino34 wrote: ↑
09 Jan 2025, 17:44
wtf I fixed it i used chatgpt to suggest a way to solve it, and it was right. I had to download Equalizer APO and the Peace addon, install APO on the devices I use, and with the Peace addon, add the delay. In my case, I had to set it to 320, and that was it—problem solved I can't believe it
Pls explain more
I have the same issue
Downloads pls
It's just that, you need to look for a program called Equalizer APO, which is on SourceForge, and install it on the devices you use. I installed it on my headphones, microphone, and speakers.
Once you've done that, install the addon called Peace GUI, which is also on SourceForge. When you install it, it will tell you that you need to install Equalizer APO first.
When you have everything set up, open the Peace addon, which will appear in the Windows start menu. Go to the effects section, and where it says "Channel Delay," start adding delay. Obviously, it’s better if you use some audio and video sync test video to adjust it and test
So shooter games are now fixed ?
Asesino34
Post by Asesino34 » 14 Jan 2025, 19:09
Unreazz wrote: ↑
10 Jan 2025, 17:19
Asesino34 wrote: ↑
10 Jan 2025, 16:44
bwainzz wrote: ↑
10 Jan 2025, 11:16
Asesino34 wrote: ↑
09 Jan 2025, 17:44
Pls explain more
Downloads pls
Well, I don't know if it's fixed, but I can play a bit more comfortably. Let's say I feel like I can play a bit more aggressively and not so scared. But it all comes down to how each person feels, so this is just my experience
