Dalek
Post
by Dalek » 19 Dec 2025, 16:09
BustingBlur wrote: ↑06 Dec 2025, 15:46
Appreciate the links!
These look to be only Adaptive Sync monitors meaning they won't have Low Frame Compensation, which could help with the 27" 1440p situation.
GIGABYTE M27Q3 any good?
Sorry for the delayed reply, I didn't see this post.
No problem! Yes, Gigabyte's monitors in general have great performance and value for the price. I personally would say go for it.
Monitor's unboxed has also given it a positive review:
https://youtu.be/56EPH-MibMM
FuzzyPenguin
Post
by FuzzyPenguin » 22 Dec 2025, 05:47
For a great 1080p Steam Machine, a 24–27 1080p IPS screen with 144Hz FreeSync and good overdrive (no strobe) is perfect. It's smooth, easy on the eyes, and will last without being too much for your system.
Post
by Chief Blur Buster » 23 Dec 2025, 12:08
A 240Hz monitor with a VERY GOOD 60-120Hz capability is warranted, and that's the ViewSonic XG2431.
www.blurbusters.com/xg2431
I helped ViewSonic make this 240Hz one of the best 60-120Hz blur-reducing monitor for gaming consoles.
Obviously, it's LCD and all that entails. If blacks and HDR colors are your priority, you may want a 4K OLED and just run it at 1080p. But you did mention a desire for motion blur reduction, and I wanted to highlight a good 60-120Hz monitor because sometimes a well-tuned 240Hz panel with low-latency 60-120Hz modes with unlocked strobe range.
BustingBlur
Post
by BustingBlur » 24 Dec 2025, 16:29
Chief Blur Buster wrote: ↑23 Dec 2025, 12:08
Thanks for the recommendation, I was checking this out originally but was under the impression it will require the strobing tech to be enabled to get the best out of it?
1080p - Check
>120Hz - Check
FreeSync Premium - Check
As mentioned, I want a plug and play experience as it will be for young eyes - do you think it is suitable for playing games that is likely to fluxtuate in regards to framerate between 48-240 FPS? (Thus with VRR fluctuating the monitors Hz) - is the IPS Overdrive variable in that it will minimise ghosting regardless of the frames or that doesn't matter thanks to the strobing? (As the machine is weak, more demanding games may fluctuate more often)
What would the recommended settings be? As in, what setings are recommended to be turned on/off for best viewing experience and minimal eyestrain or negative side effects.
Look forward to your response and eagerly waiting to pull the trigger on a suitable monitor.
