Page 2 of 2
Re: FIXED ELECTRICITY INPUT LAG
Posted: 28 Dec 2025, 17:13
by Slender
menzukii wrote:
28 Dec 2025, 14:51
I apologize for my English
I posted that a loose connection on the neutral wire was causing my latency issue. I simply replaced the bimetallic connector that connects my house's power line to the transformer, and the problems were resolved.
My house doesn't have grounded outlets, so it's not a grounding issue.
I think the solution is simpler than it seems. The problem is that even with a loose connection on either the neutral or live wire, the multimeter readings appear normal. My readings were 125-127 V, and the same current flowed between the live and neutral wires without any apparent problems. The wire resistance was also measured.
neutral resistance?
