Page 2 of 2
Re: PG27AQDP - can it do 1440p/360hz/8-bit over HDMI 2.1 with DSC off?
Posted: 16 Aug 2026, 15:42
by t2na
ekajjj wrote:
14 Aug 2026, 23:14
I am on a 4070 FE. I am guessing it may be my card. I am considering upgrading, we'll see. Do you think it is worth it to run without DSC at 300hz or just keep DSC and 500hz and why? Appreciate your help - truly.
No worries at all!
Depends on the games you play if you're even hitting the 480hz/fps range as to whether it's worth it. I try to turn off DSC where I can but honestly I'm not sure I notice the difference between them in game.
And because I'm on a 50 series card I don't have any of the black screen issues that I know are a frustration on the 40 series cards. If it was me, I think I'd be happy with either option. 300hz no DSC or 500hz with DSC, two pretty nice options to have!
