I know that i'm stressing, but maybe it's because i don't have the necessary knowledge to decide what's the best to buy...Falkentyne wrote:Just import an XL2420Z then. it isn't THAT hard if you have money.
Money doesn't grow on trees, yes, but you also can't take it with you. STOP STRESSING so much over minor things and GO buy your monitor!!
As I said the XL2430T has BUGS in profiles (the older Z series had bugs too, but that was mainly due to low blue light and one other profile setting not being "available" to be selected if you saved a setting which had that profile there; that profile bug was fixed in V3 firmware on the Z monitors).
If you are 100% sure you do NOT need the DP port, get XL2411Z V4.
If you think you might in the future, and can deal with the profile bugs and working to get a good image on the XL2430T, get it.
Or pay the extra money for a better blur reduction toggle mode and get the XL2720Z (v4 firmware).
Or import the XL2420Z V4.
And stop worrying so much.
However you should not feel stressed, you can just ignore at this point... Thanks anyway
