Overclocking MSI Optix MPG341CQR to 215 Hz [SUCCESS]
Re: Overclocking MSI Optix MPG341CQR to 215 Hz [SUCCESS]
Post by RealNC » 13 Nov 2021, 15:05
LOV wrote: ↑
12 Nov 2021, 17:30
So have you tried to use the same timings in CRU?
LOV
Post by LOV » 13 Nov 2021, 16:39
RealNC wrote: ↑
13 Nov 2021, 15:05
LOV wrote: ↑
12 Nov 2021, 17:30
Yes i did :(
LOV
Post by LOV » 13 Nov 2021, 18:53
LOV wrote: ↑
13 Nov 2021, 16:39
RealNC wrote: ↑
13 Nov 2021, 15:05
LOV wrote: ↑
12 Nov 2021, 17:30
I've recorded a video, so you will see the way i do with CRU:
https://drive.google.com/file/d/1CoRgl- ... dbiy7/view
LOV
Post by LOV » 13 Nov 2021, 20:17
Ok, i found the solution and it works perfectly 8-)
I've deleted custom resolutions from NVIDIA Panel
Launch CRU delete everything then,
Add 1 Extension Blocks > DP 1.3 > Detailed resolutions > Add > I copied the exact same timings from NVIDIA Panel > Launch restart64.exe
If you have this monitor, I advise you to use 214hz because ALT+TAB is bugged with 215hz (Black Screen, DP not detected)
PROBLEM SOLVED ;)
