Thanks for mentioning this, I play very competitive Call of Duty and my eye gaze is always wondering around the crosshair looking for the enemy. I've been using the MSI currently and although the Anti-Blur is nice, the fact that you lose more than half your brightness has been a real pain in the ass. I've absolutely lost enemy positions and lost gun fights because of this.speancer wrote: ↑02 Sep 2020, 08:29You might find it limiting once you've used a monitor that does a better job in motion handling. I recently tested MAG251RX and Zowie XL2546, and from my latest testing the Zowie one is noticeably better in terms of motion handling. After I played a few days on XL2546 and then switched back to MAG251RX, it looked significantly less clear and more blurry to the level I just returned it and, for now, kept the XL2546. Also, Zowie monitors have very good motion blur reduction technology called DyAc, with manageable crosstalk and no brightness impact. I personally don't use it, because it doesn't help if you use fixed-gaze (stare-at-crosshair-only) aiming technique, but in eye tracking situations (out-of-crosshair) it's helpful. XL2546 is also a lot better in terms of ergonomics.Binder87 wrote: ↑02 Sep 2020, 03:34I tried to activate amb but the monitor gets too dimm for my taste....i play comp csgo, and fine attention to details (in terms of noticing enemies) is more important than anything else (picture quality wise). That's why i use brightness and contrast at really high level, way above whats usable for anything else on that monitor like web browsing etc, so unfortunately i cant really use abm. I don't find the motion blur a limiting factor while playing , so im ok with it.
Also, BenQ Zowie is about to announce their new flagship e-sports monitor this month apparently, so I'm also curious about their new offering.
I know you didn't use the DyAc+ with the S series that just got discontinued, but do you think it will add monitor lag with it turned on? My RTX2080Ti can generally pull about 210FPS while playing ideally, I need the best antiblur motion whilst keeping input lag at close to 0 as possible.
