i wish i know how this all emi shit works and why somebody doesnt have issue and why some dowyrko_o wrote: ↑03 Jan 2021, 07:02You just made me think of something. All the pcs I've had were overclocked and also most of them with higher voltages. I've had the problem on all of them. I have never thought that I have EMI in my house, also my electricity is grounded.Unixko wrote: ↑03 Jan 2021, 06:53with EMI around you need less power to your components more voltage=more emi = worse pcwyrko_o wrote: ↑03 Jan 2021, 06:40So basically I have lowered the voltages that my MB supplies to all of my laptop's components? Well that explains it all. The thing is that I am able to reproduce it, so I have finally found the culprit of my problems and also how to fix it. But I still don't get it, how could lowering the voltages make my system feel better, make my input and visual lag go away, make my gaming experience so much better? Isn't it supposed to run better with higher voltages, I mean isn't lowering the voltages supposed to cause powerthrottling?
Input lag cs:go / choppy/unsmooth
Re: Input lag cs:go / choppy/unsmooth
Have you checked for heat issues? If you get too hot your shit downclocks....lower voltage might have fixed your temps.
